Home > Td5 > Bulkhead repair & parts to buy
excossack
Hopefully I am getting the bulkhead repaired soon (rust under the windscreen bracket) and so are the windscreen blocks/hinges
Also the windscreen surround is showing some corrosion so I think its a good time to get that repaired/replaced as well.
Parts off the top of my head I might be needing;
New windscreen block seals
New top of bulkhead to windscreen foam seal
Top of windscreen frame to roof seal
Windscreen surround rubber 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #491901 13th Jan 2016 7:34pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
As the dash will be apart you could fit new wheelboxes for peace of mind, always worth a small collection of screws/fixings and check all your gauges/warning lights as bulb replacement will be easy with it removed. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #491933 13th Jan 2016 8:45pm
excossack
I replaced the wheel boxes last year. TBH I was hoping to leave the dash in place as its just
the outside of the bulkhead / wing mirror area.. Planning on buying a repair section that includes the vent surrounding. 1999 Defender TD5 110
Regards
John M0VAZ
Post #491975 13th Jan 2016 9:45pm
Mash
In that case lots of cavity wax to soak the internals whilst the bulkhead is cut open, also a weld through primer is good if you want a little extra protection on the repair. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #491996 13th Jan 2016 10:15pm
excossack
Cavity wax is a must. I am send the 110 into a body shop for the work and spraying. 1999 Defender TD5 110
Regards
John M0VAZ
Post #492021 13th Jan 2016 10:42pm
JWL
Another thing to add to the wheelboxes whilst the dash is out, if you haven't done it allready, do the double washer set up with standard jets in both the holes where the wipers are driven when LHD. Plus you could put some pipework in from the heater box to give you side window demisters.
Post #492047 13th Jan 2016 11:09pm
excossack
Extra washer jet has been done also (when I did the wiper boxes)
Has anyone tried these repair panels?
http://www.ebay.co.uk/itm/LAND-ROVER-DEFEN...Track=true 1999 Defender TD5 110
Regards
John M0VAZ
Post #493248 17th Jan 2016 1:30pm
Mo Murphy
Cavity wax before you weld is probably not a good idea ...
50 Shades of Pennine Grey
Post #493258 17th Jan 2016 2:22pm
shaggydog
I wish those repair panels had come out before I did my bulkhead repair - would have sped it up no end!
Don't fill it with wax until after the weld has been done or it can catch fire inside and that would be disastrous. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #493274 17th Jan 2016 3:23pm
