![]() | Home > Tdi > Clutch Issues 300 Tdi |
Graham Russell Member Since: 09 Apr 2010 Location: Auckland Posts: 2 ![]() ![]() |
Seeking ideas on a 300 Tdi 110 clutch issue I have.
I can't get it into gear with the engine running. I have replaced the clutch plate ( Valero), pressure plate, release bearing - twice, it has a new strengthened clutch fork and new fork pivot. It has had three slave cylinders and 3 master cylinders - the last one being 7/8 ths bore to get more movement on the slave cylinder. The slave cylinder push rod is good. It was put together with the push rod clip in place. The clip holding the release bearing to the fork wasn't replaced but I can't see this causing my problems. About to take it apart for the third time but am at a lost to what the problem might be unless it is the spigot bearing or I haven't aligned the plate properly. Any thoughts appreciated. No matter what I have done the problem has stayed the same. Cheers, Graham Auckland NZ |
Biffas Member Since: 30 Dec 2015 Location: Surrey Posts: 122 ![]() ![]() ![]() |
silly question but have you got the clutch plate round the right way?
Thanks for the replies.
Clutch plate will only go in one way. Impossible to get around the wrong way. I have changed the arm for a strengthened one, so there is a possibility it may not be quite as per original but I should see marks on the bell housing if that is the case. It is going to be something obscure but silly I think. Cheers, Graham |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8476 ![]() ![]() ![]() |
thats what i was trying Cheers
nickhodgson Member Since: 08 Dec 2009 Location: Zambia Posts: 174 ![]() ![]() |
It may help to add some pictures of what the engine side and gearbox side look like before you put then together. Does the gearbox go into gear when not connected to the engine and why did you replace the clutch in the first place. Also what part numbers are you using? Is the push rod the correct 300tdi one?
Cheers Nick 1995 300tdi Defender 90 P/UP 2011 Puma Defender 130 D/C 2000 300tdi Defender 110 P/UP 2015 Discovery 4 SDV6 HSE |
LRmud Member Since: 22 Oct 2014 Location: IV12 Highland Posts: 198 ![]() ![]() ![]() |
Could it be something to do with the gear selector bias springs requiring adjustment. Is is all gears or just a few?
I had this problem and my first instinct was to start swearing at the clutch until I found that some gears worked OK - then I started swearing at the gearbox - then I found out about the bias springs below the gear stick! ![]() After adjustments made, all was good again. -------------------------------------------------------------------------------------------------- 1989 Defender 90 Toyota Aygo & Honda FR-V |
Thon Member Since: 22 Nov 2015 Location: Salisbury Plain Posts: 696 ![]() ![]() |
Is the master cylinder pushrod position adjusted so that you achieve full movement? IIRC there are locknuts that set the position of the pushrod Vs the pedal, and if this isn't correct then you may not achieve enough stroke to displace enough fluid to the slave?
Dave T Member Since: 07 Jun 2013 Location: Glasgow Posts: 492 ![]() ![]() ![]() |
Not true..... when I was rebuilding mine a friend put the clutch plate in, and then when tested I'm sure it wouldn't transmit drive. We had the gearbox in and out several times before I spotted that he had put it in the wrong way round! Just found an old post, it wouldn't release, just rattled 2015 RRS Autobiography SDV6 1994 Def 90 300tdi |
Bumpymike Member Since: 18 Nov 2015 Location: cheshire Posts: 71 ![]() ![]() ![]() |
What's the spigot bearing like in end of crankshaft?
If gearbox main shaft is tight in spigot bearing it could be picking up drive ? |
dailysleaze Member Since: 23 May 2013 Location: United Kingdom Posts: 237 ![]() ![]() |
There were two types of slave cylinder and push rod for the R380. The push rods are different lengths so have to be matched to the correct slave cylinder. Check you have the correct part number or that it matches the one taken off.
^^^ ref lengths, had this issue yesterday!
likewise spigot bearings is very valid point, one that came out yesterday was failing in a big way. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
