Home > Maintenance & Modifications > 300Tdi upgrades pros and cons ?
Page 2 of 2 <12
miker
Never really thought about it. But yes!
Although the folds in a paper filter mean it has loads more surface area than a flat piece of the same material. So you could achieve the same level of filtration with higher flow if you had more folds, and thus more surface area
Post #489686 7th Jan 2016 7:26pm
dave18
United Kingdom 1984 Defender 110 300 Tdi CSW Portofino Red
Think we will steer away from the never ending Stock v Performance filter!!!!
Stock size Intercooler or full width ??
Post #489712 7th Jan 2016 8:20pm
L110CDL
I would go the full width intercooler, slots in between the radiator and front grill with no problems, i got one on mine, its made a big difference Thumbs Up
Clayton.
Post #489762 7th Jan 2016 10:20pm
dave18
How does it plumb up?? Same place as the original or do you need to run different hoses??
Post #489804 7th Jan 2016 11:46pm
L110CDL
Same as the other hoses, as long as you get an intercooler for the 300tdi only, not the ones you see for sale as 200/300 tdi, they need slightly different hose work due to the different angle on the intercooler where the hose connects to, you can see this if you go on the Alisport website, hope this helps.
Clayton.
Post #489809 7th Jan 2016 11:54pm
Page 2 of 2 <12
