Home > Maintenance & Modifications > Rear demist switch for reverse lamp?
ibexman
I don't use my rear widow exist could this be used for work/reverse lamps ?
Post #487809 2nd Jan 2016 3:52pm
PaulMc
Hi Chris,
Yes you could use the HRW circuit Thumbs Up
The HRW switch switches a relay, which supplies the rear window heating element on 1.5mm˛ cable, which is good for 20A.
You can easily pickup the feed at the chassis harness/taildoor harness connectors C0704/C1102 -
I can do you a male terminal and seal pre-crimped to 1.5mm˛ cable, to replace the taildoor harness terminal in C1102
Cheers,
Paul.
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Paul.
Post #487836 2nd Jan 2016 5:20pm
ibexman
Hi Paul you have PM Thumbs Up
Post #487856 2nd Jan 2016 6:34pm
