![]() | Home > Maintenance & Modifications > What's next for 2016? |
Hufflepuff Member Since: 25 Oct 2014 Location: Hampshire Posts: 727 ![]() ![]() ![]() |
And me. That looks like a much better place to put the underseat relays, is that what it actually is?
ericvv Member Since: 02 Jun 2011 Location: Near the Jet d'Eau Posts: 5817 ![]() ![]() ![]() |
It is indeed a amended seat box housing all the relays and fuses for everything installed after market, so nothing to do with the original factory electrics. Clean solution, good access, easy to label as required.
I will have this installed after the winter to clean up my under bonnet relays, fuses and wiring spaghetti for the fogs, DRL, etc. Location of these relays inside the cabin with easy access is going to be much better than under the bonnet. Once it is all installed in its final configuration, I will happily provide more info. ![]() Eric You never actually own a Defender. You merely look after it for the next generation. http://youtu.be/yVRlSsJwD0o https://youtu.be/vmPr3oTHndg https://www.youtube.com/watch?v=_GtzTT9Pdl0 https://www.youtube.com/watch?v=ABqKPz28e6A https://www.youtube.com/watch?v=rLZ49Jce_n0 https://www.youtube.com/watch?v=XvAsz_ilQYU https://www.youtube.com/watch?v=K8tMHiX9lSw https://m.youtube.com/watch?v=dxwjPuHIV7I https://vimeo.com/201482507 https://www.youtube.com/watch?v=ZSixqL0iyHw |
