Home > Puma (Tdci) > How to Check Tank for Water
CapeLandy
South Africa
Had a quick look under the tank but can't find a drain plug.
Can one siphon from the filler right to the bottom of the tank to get rid of any water?
Any ideas?
James Puma 110 - gone
Series III 1973 - going strong
Post #2912 25th Jul 2008 1:01pm
Tim_NZ
Australia
Hi James, I'm not sure how to drian the tank, knowing LR you probably have to remove the tank!!! You can drain fuel at the filter/seperator and check for water. You'll just need to fit a length of hose to the drain point and undo the drain on the bottom of the filter 1-2 turns.
Be aware though the workshop manual says you need to then bleed the low pressure fuel system with a special tool.
Why they couldn't fit a hand pump on the filter assembly like most other diesels I don't know, or even have a purging procedure like the TD5.
Tim
Post #2913 25th Jul 2008 3:34pm
CapeLandy
South Africa
air lock
I did already drain the filter but only until I got clean diesel so it was only 100ml or there abouts.
I started the vehicle and luckily there was no aparent air lock.
I looked in the Puma manual but did not find a bleeding sequence but then again I don't have the workshop manual as I beleive it's not out as yet.
Where did you get one Tim?
Thanks
Post #2919 26th Jul 2008 6:27am
Tim_NZ
Australia
Hi James, I havn't got a workshop manual, I get all of my info from the LR Global Technical Reference Website:
http://www.landrovertechinfo.com/extlrprod/market.jsp
You have to register and pay to use it. You can ger 24hrs access for $14USD for one vehicle.
Tim
Post #2941 27th Jul 2008 2:38pm
dullbird
Australia 2007 Defender 110 Puma 2.4 SW Tonga Green
if you register for your vehicle you can access the workshop manual i have! YOU KNOW REHAB IS FOR QUITTERS!!!!
Post #2952 28th Jul 2008 12:43pm
mse
For free against the car?!
Ive only seen the pay option, where is the free one... Mike
Post #2960 29th Jul 2008 9:38am
dullbird
no sorry when i say register i mean subscribe.......nothing in this world is free especially from landrover Wink YOU KNOW REHAB IS FOR QUITTERS!!!!
Post #2961 29th Jul 2008 9:57am
mse
Great - for a minute i thought there may have been a none pay way. Mike
Post #2962 29th Jul 2008 10:00am
CapeLandy
South Africa
14$/24H
Does the 24 Hours give you time to download all the manauls or what exactly are you paying for? Puma 110 - gone
Post #2964 29th Jul 2008 11:39am
dullbird
Re: 14$/24H
i would imagine that 24hrs would give you enough time to print all the manual if you had a fast printer and lost of ink and you were prepared to sit at your computer for some long hours!!
you cant download from the site only print YOU KNOW REHAB IS FOR QUITTERS!!!!
Post #2965 29th Jul 2008 11:59am
CapeLandy
South Africa
So how do you make use of the site without becoming bankrupt Confused Puma 110 - gone
Post #2966 29th Jul 2008 12:13pm
one_iota
Australia 2008 Defender 110 Puma 2.4 SW Alpine White
I purchased a month's subscription (for one model and one model year).
I use pdf printer software (Google: "CutePDF Writer" which is a free down load) to save the info I am after to my 'puter.
With the exception of the detailed electrical componentry it would be possible to download all the information available within the 24 hour period if you set aside several hours.
You cannot print a complete workshop manual in one go...only in sections so it is a bit fiddly and you might want to be selective about it. Particularly the "Electrickery" parts. Mahn
'08 Defender 110
ex '95 Disco 300 Tdi
www.aulro.com
Post #2977 29th Jul 2008 11:21pm
mse
Can you not use the print to file function and print it to a file - then compile it back to a pdf - ive done this a few times on secured pdf's
Who is to be the first kind person to download them and then post them Rolling Eyes Mike
Post #2978 29th Jul 2008 11:29pm
CapeLandy
South Africa
Come on Sydney - how bout a scan and e-mail to us poor fella's Wink Puma 110 - gone
Post #2979 30th Jul 2008 4:57pm
