![]() | Home > Td5 > Headlight switch turns alarm on not headlights .plz helpHelp |
JAY BOY Member Since: 04 May 2010 Location: Not here Posts: 1706 ![]() ![]() |
Could be a bad earth somewhere
Collydog Blue Member Since: 06 Dec 2013 Location: Stockport Posts: 26 ![]() ![]() ![]() |
Thanks jay, got the steering colum housing off looking around as we speak,
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1751 ![]() |
Under bonnet on bulkhead undo nut and clean all connections
also try unplugging towing socket driver side back wheel arch
Thanks everyone, still no joy, will try the above thanks again.
![]() Just found oil in my ECU plug now.... ![]() |
time for new injector harness and brake cleaner as well
Thanks Dorsetsmith, I'm gutted, only had it done last year.
in that case check head end for oil if none seen, clean red plug out with brake clean
had to do my one sume year ago to take at lest month to get oil out of the loom |
Will do, thanks for your help.
mrd1990 Member Since: 16 Aug 2012 Location: Wales Posts: 605 ![]() ![]() ![]() |
I had the same problem when I accidentally connected the positive headlight feed to the ignition negative (long story)... Anyway, it blew a fuse and I had to do an emergency field repair
![]() Click image to enlarge Check that fuse under the driver seat, first long one on the right ![]() |
Thanks mrd1990, I did check my fuses last night, but it was dark and I did have my stress head on, will have a closer look today when the stress monkey has gone. Thanks again.
Well, checked all joints, fuses, and cleaned oil out of ECU plug still no luck, also tried disconnecting the battery to see if it would reset it, but still the same problem.
Going to start from scratch tomorrow checking all joints again, and bulbs etc, if anyone has any other ideas I would be eternally grateful. ![]() ![]() ![]() |
