![]() | Home > Td5 > Central Locking/alarm |
Romadog Member Since: 07 Jul 2011 Location: Powys Posts: 1751 ![]() |
All that you list. Get a S/H bulkhead loom and extract the relevant wiring and yes you need a specific 10as unit with relay inside for central locking. Mod can be done, but I suggest plug and play is best if you can for majority of connections so its easier to trace any faults that may occur in the future.
PaulMc Member Since: 17 Jan 2009 Location: Kent Posts: 510 ![]() ![]() ![]() |
I can do you the connectors to mate with the factory door harnesses, see here -
http://www.defender2.net/forum/post124863.html#124863 I can also supply the proper NEC relay to solder to the non central locking 10AS, to make it into a central locking 10AS - ![]() As well as the additional terminals you'll need for the central locking and control circuits in the 10AS unit's Grey and Green connectors - ![]() Click image to enlarge . Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() 1989 Arles Blue 2.5TD 110 Hardtop 1999 Epsom Green Discovery II 4.0 V8i 'XS' |
Welkman Member Since: 02 Nov 2014 Location: Essex colchester Posts: 333 ![]() ![]() |
paul I would love to go down this route. I did quite a bit of soldering at school so I am up for the challenge. Will PM you.
achuakh Member Since: 12 Apr 2012 Location: Singapore Posts: 161 ![]() ![]() ![]() |
It's not difficult.
Just the relay and then because i didn't have the connectors i pulled out pin 2 and 3 thru a hole i made in the side of the 10AS. I already has some after market acuators on the doors, so i just used those to directly drive them. You have another option if you don't want to add the relay but have after market central locking. if you have a 5 wire master acuator, you can also hook the signal that is used to drive the relay to the wires on the master acuator. You will need a nanocom or similar to program the 10AS. again not difficult if you know what you are doing. there's information on the blackbox diagnostic on what each of the functions do. The defender has migrated, leaving the owner behind. |
