![]() | Home > Maintenance & Modifications > Replacing door hinge pins |
you can drift out pin, but door hinge are only sold complete
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17874 ![]() ![]() ![]() |
I have never actually managed to remove the pin from a standard Defender door hinge, though I have several times read (as above) that it is theoretically possible, and I suspect that the pin is 'upset' after fitting to swell the lower end to prevent removal.
In practice it seem that you have to replace the hinge complete. |
excossack Member Since: 22 Feb 2012 Location: North West Posts: 6013 ![]() ![]() ![]() |
So new hinges it is then. Another job on the list (that does not appear to get any shorter) 1999 Defender TD5 110
