![]() | Home > Maintenance & Modifications > Very cold weather mods |
Looks a great idea but maybe a bit overkill for this country? Ray
Kenlowe used to make a mains block heater that heated and circulated the coolant
Also if you have a 2.4 or a 2.2 and venture in temperatures less than -20c ish.. You'll need a breather heater or a new engine when it freezes up |
Mike_B Member Since: 23 Jan 2011 Location: Moray Posts: 550 ![]() ![]() ![]() |
Are you connected in any any to Defa warmup?
Interesting post Bumpymike
![]() You got any pictures of your installation? Another route is to to install a Webasto Thermotop fuel burning heater to heat the block before starting ![]() Self confessed mileage hunter ![]() |
I thought that was just for the 2.4, the 2.2 has a different arrangement? |
Bumpymike Member Since: 18 Nov 2015 Location: cheshire Posts: 71 ![]() ![]() ![]() |
No. I fitted it for a trip in Feb 2014 to top of Norway via Finland / Sweden, and just planning another winter 'walk about' so thought it may of been of interest to folk who live high up in Scotland who looking for a warmer vehicle in the morning. |
I considered the Thermotop but worried about battery drain and with a eberspacher in rear had already fitted an additional pickup into fuel tank and this was easier option to fit. Will get some pictures in daylight if it stops raining !!! Here is one for fuel heater. ![]() Click image to enlarge |
Not sure, the pipe from the rocker cover to the airbox freezes up on the 2.4's, maybe the 2.2's are different , so I'd say if the pipe exists on the 2.2's check with LR |
Cetane Member Since: 27 Nov 2012 Location: Lancashire Posts: 171 ![]() ![]() ![]() |
Im curious. How does this kill your engine?
Phoenix90 Member Since: 04 Mar 2012 Location: Cornwall Posts: 377 ![]() ![]() ![]() |
Not seen this brand before
![]() I've always steered away from the electric ones as i've found that even in the most northern parts of Scandinavia hook in power sockets are not always reliably available and the FBHs use very little battery, but at �400.00 it is a well priced alternative. What winter 'walk about' are you planning?? |
jimbob7 Member Since: 06 Jul 2013 Location: uk Posts: 2055 ![]() |
Lots of generic �100 engine coolant heaters available on eblag.Dunno how reliable they are tho. Pov.spec,ftw. 2006, 110,TD5.
More likely drive up to Finland and fancy do some ice driving on a Lake (in one of there cars) and then may go top of Norway again or Murmansk to see the Nuclear ice breaker or drive back around Finland to Helsinki and get ferry to Estonia and drive back via Latvia, Lithuania, Poland and Germany. |
Sounds good!
![]() Up through Sweden to Finland?? |
take freight ferry DFDS from Immingham to Goteborg....up through Sweden
