Home > Td5 > Viscous fan
excossack
Viscous fan
Should the viscous fan be difficult to spin while the engine is off and cold? Or is this a sign of it being seized? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #477487 29th Nov 2015 9:56pm
Retroanaconda
You will find if you keep turning it it will free up a bit if working properly. The fluid settles a bit so it will be stiff from rest.
Best test is to start the engine from cold, let it idle for a few seconds, and then try to stop the blades with a rolled up newspaper. Should be able to stop it fairly easily. Once hot it should turn the newspaper into confetti.
Post #477495 29th Nov 2015 10:09pm
Alex1976
It will be quite stiff for the first few turns but then should loosen up. It still won't spin really easily though, so unless it is really hard to turn then it sounds ok.
Post #477496 29th Nov 2015 10:11pm
