Home > Maintenance & Modifications > Gearbox woes
JWL
Gearbox woes
One for the armchair mechanics to peruse whilst letting their dinner go down on a Sunday afternoon.
My 2002 Td5 110 is starting to give me grief, I have lost synchromesh from 3rd into 2nd and now need to double declutch if 2nd is needed. I have also had it "lock" the gearbox much like putting an automatic into park when going from reverse to first, a little rock on the clutch or a roll if there is enough slope and it will release. There's no problems in any other gear.
In my mind this is pointing to the selector for second is loose allowing it to float around and causing the problem.
We all have a Nemesis, and gears and their trickery is mine!
Post #477386 29th Nov 2015 5:43pm
JWL
Could I just give this another try Whistle
Post #477816 30th Nov 2015 10:12pm
jst
what about rev to another gear? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #477831 30th Nov 2015 10:35pm
JWL
I had another "lock up" of the gearbox tonight, I had reversed, stopped and when I went to take it out of reverse and take it out of reverse there was resistance from the gear lever so I eased the clutch up gently the gearbox had "locked". It did come out but I heard the sound of gears spinning as if trying to mesh. Clutch back in and normal drive was resumed.
Post #477844 30th Nov 2015 11:18pm
