Home > Td5 > Erratic fuel gauge
Clive
Erratic fuel gauge
Just recently the fuel gauge in my Td5 90 has developed a mind of it's own.
It used to read normally but now it often starts off reading empty even with a full tank, the reading sometimes slowly increases to full over a period of 20 - 30 minutes or sometimes stays empty, when it's showing empty the low fuel light is on also. No other instruments seem to be affected.
My suspicions are leaning toward the sender or wiring from it because of the low fuel light.
I'm just wondering if it's something common and anyone else has come across this fault, I can't seem to find anything with a search - and it's cold & dark outside just now.
Post #476756 27th Nov 2015 6:43pm
dorsetsmith
cct for your fuel gauge start by checking plug and sockets sound like bad connection or wire short out ,wiring making and breaking
Post #476768 27th Nov 2015 7:18pm
Clive
OK cheers, I'll check it out in the morning if the weather holds out, just need to find where the relevant connectors are, hoping I don't need to drop the tank Rolling Eyes
Post #476840 27th Nov 2015 10:01pm
Clive
I think I've found the answer to my original question.
I suspect that there is a poor connection on the potentiometer track of the fuel gauge sender, I've realised now that the fault only occurs then I've filled the tank to the brim, shortly after driving off the gauge goes to empty and the low fuel light comes on, after 50 miles or s it starts to indicate more fuel and by 80 miles or so it's back to normal.
I always make a point now of re-setting the trip-counter every time I fill up as a guide to fuel usage so I'm not going to bother trying to fix it for now.
Post #506089 19th Feb 2016 11:56am
Kent_keith
England 2005 Defender 90 Td5 CSW Zambezi Silver
This is exactly what my fuel gauge does? Just to let you know you're not the only one Thumbs Up 2005 TD5 90 CSW XS
Post #506585 21st Feb 2016 8:15am
Giby_off
Bulgaria 2012 Defender 110 Puma 2.2 SVX Station Wagon Havana
How did you fix it? I have the same problem.
Post #690868 4th Mar 2018 4:47pm
Clive
I've not fixed mine yet, I think I'll have to drop the tank and replace the sender - eventually.
It works normally from about 3/4 tank down so it's not a big problem, TBH it's quite low on my priorities list just now.
Post #690878 4th Mar 2018 5:28pm
gilarion
That a really good tip. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at..
Post #690895 4th Mar 2018 6:32pm
dorsetsmith
having just replaced fuel pump on the 03 90 HT pump nose with low presser 2.1 bar not good and low engine power new pump in sorted Smile long over due
fuel pump bottom filter blocked clean out will test later then new part arrive finger crossed
tank sender resistor
E = 326 ohms
1/4 = 245 ohms
1/2 = 121 ohms
3/4 = 63 ohms
F = 8 ohms
Post #690934 4th Mar 2018 8:26pm
Old thread revival!
did anyone get to the bottom of this? Mine is now doing the same thing.
Post #813848 5th Feb 2020 11:53pm
Clive
Mine is still doing the same, after 4 years it's not got any worse, it only reads empty shortly after completely filling the tank and then goes back to normal after I've used a gallon or so, (apart from after about 300 miles when it is actually empty.)
I'm 100% convinced it's a high resistance spot on the sender potentiometer, It's completely predictable so for me, it's not worth the hassle of replacing it.
Post #813876 6th Feb 2020 10:22am
