![]() | Home > For Sale & Wanted > [Wanted] TD5 90 Rear Seat Belt Bar Support Bracket (X member |
landybear Member Since: 18 Oct 2015 Location: Tamworth & Worcester Posts: 134 ![]() ![]() ![]() |
Bump 2003 Defender TD5 Hardtop (current - work in progress)
2014 Discovery 4 HSE (Current) / 2009 Discovery 3 HSE 2009 (Previous) Disco 2 Landmark 2004, 2001, 2002 (Previous) Disco 1 300tdi 1996 & V8i 1995, 200tdi 1993 (previous) Defender 110 300tdi 1993 (Previous) Range Rover Vogue 4.6 - 2001 (Previous) Freelanders TD4 (2001 3 door & 2002 5 door) Previous 90 2.5 then converted to V8i (1990), 90 2.25 then converted to v8 (1986) plus others |
Mat90 Member Since: 29 Mar 2016 Location: County Durham Posts: 3 ![]() ![]() ![]() |
Dragging up and old post but I'm also looking for these brackets. Plenty of google searches are bringing up nothing
130dreamer Member Since: 29 Feb 2008 Location: Romford Posts: 100 ![]() |
I am pretty sure I have a pair of these brackets. Unfortunately they are at my lock-up which I cant access at the moment, there is no way I could justify it as an essential journey.
If you can wait until the lock down restrictions are lifted to allow wider travel I will dig them out for you. |
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 675 ![]() ![]() ![]() |
They were fitted to 110 station wagons from 1996 onwards, should help widen your search.
Bps Member Since: 14 Feb 2016 Location: Lancashire Posts: 844 ![]() ![]() |
Message mdm on the forum He May have some
TTF Member Since: 02 Jan 2012 Location: Wiltshire Posts: 305 ![]() ![]() |
These are from a 110 but are different at one end from your photo.
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge 110 First Edition, NAS, 50th, SV, 90 CSW 300 Tdi Series 2a SWB 200 Di |
Thanks for the offer 130dreamer, I was hoping to get them replaced while I'm on furlough but if im unsuccessful then I will happily buy them from you when this is all over and done with
Mine is a 90 csw so I only need the parts that are in your second picture TTF
landy andy Member Since: 15 Feb 2009 Location: Ware, Herts Posts: 5983 ![]() ![]() |
Mmmm. I did have some. Can’t remember if I sold them or not.
Looks like I sold the ones I removed from my 110td5. But does show you what they look like.
https://www.defender2.net/forum/topic67685.html |
