Home > Maintenance & Modifications > Extended mirrors for towing
Page 2 of 4 <1234>
De nada mi amigo.
Post #42366 10th Oct 2010 4:59pm
nicks
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Alaska White
Why is it a legal requirement?
Post #42422 11th Oct 2010 3:54pm
Laurie
The caravan's wider than the normal mirrors.
The law requires I should be able to see to the rear of the caravan.
Simples.
Post #42423 11th Oct 2010 4:09pm
nicks
Never heard of that one -
I tow this around -
Not had any problems yet.
Post #42424 11th Oct 2010 4:15pm
Laurie
nicks wrote:
Never heard of that one - Not had any problems yet.
Ignorance of the law is no excuse.
If you can see clearly to the rear of whatever you are towing then you don't need extended mirrors.
i.e. It's the same width or narrower than the towing vehicle.
Post #42425 11th Oct 2010 4:19pm
nicks
i'll have a look into that then
the RIB has a beam of 2.8m so alot wider than the Defender
Post #42428 11th Oct 2010 5:13pm
Eduardo
Hi there!
Thanks for all you help but finally I decide to give up the auction. 29 GBP + post for each sound quite expensive.
Thanks in advance I will see another solution. Eduardo
Post #42436 11th Oct 2010 6:23pm
Laurie
I'f I come across any more at £12 each, would you like me to buy some?
I could always sell them on if you changed your mind.
Post #42441 11th Oct 2010 6:36pm
Taken from the direct.gov.uk website
Quote:
Fit towing mirrors if you need them
If your caravan or trailer is wider than the narrowest part of the rear of the towing vehicle, you must by law fit towing mirrors. These mirrors must be E-marked (mirrors with this mark meet EU requirements).
If you are towing blind (without towing mirrors) or using illegal mirrors (not E-marked) you can be:
•prosecuted by the police
•given three points on your licence
•fined up to £1,000
The "wolf" XD longer mirror arm is part # RRC 8443. not sure how much is it from LR, prolly quite a bit, but it's the same arm used on some Leyland/DAF vans (like the Post Office use), so you may get one from a DAF dealer or breakers (same thing isn't it? Rolling with laughter )
Post #42445 11th Oct 2010 7:24pm
Glynparry25
Eduardo,
I will be going back to work at the end of the month- I will see what I can find for you Wink (You will probably have to pm me on the 1st Nov)
Glyn Sheep
Post #42452 11th Oct 2010 8:22pm
Laurie
diesel_jim wrote:
.....dealer or breakers (same thing isn't it? Rolling with laughter )
I know lots of people who break things but not many dealers. Rolling Eyes
Post #42474 11th Oct 2010 10:32pm
I know dealers who break things! Whistle
Post #42498 12th Oct 2010 8:02am
Eduardo
Thanks guys for all your help.
Glyn, Laurie if you found a pair below 20£ each will be great.
We will keep in Touch.
Thanks again Eduardo
Post #42516 12th Oct 2010 1:08pm
nicks
[quote]Fit towing mirrors if you need them
If your caravan or trailer is wider than the narrowest part of the rear of the towing vehicle, you must by law fit towing mirrors. These mirrors must be E-marked (mirrors with this mark meet EU requirements).[quote]
Thats ok then, because the trailer is the same width as the Defender.
Post #42602 13th Oct 2010 4:13pm
Laurie
....but can you see clearly to the rear?
Post #42605 13th Oct 2010 4:37pm
Page 2 of 4 <1234>
