Home > Technical > Shaking Defender
Penguin
Belgium 2015 Defender 110 Puma 2.2 HT Chawton White
Shaking Defender
Ever since we had our 110 it started to shake once around 100km/h -> 130km/h
Even though it was intermittent I thought it were the wheels that are bad balanced.
So let them balance again, testing, at first ok, but then it started again.
Got them balanced with pvc balls => no avail.
So I put bak the original wheels as the def came from the dealer.
It's much better, but still the shaking / wobbling occurs.
Strange thing is, it's not all the time, and it can start out of the blue and also stop like that. (When driving the same speed)
Anyone had similar?
Thx 28/02 - Loss of a good friend...
In a time of chimpanzees, I was a penguin.
Post #474824 21st Nov 2015 1:45pm
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
Things I would check:
- Are both the driveshafts tight on both end.
- Is there play on the hand brake drum. (I had that recently. The driveshaft was tight but the nut that hold the flange had some play) Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #474867 21st Nov 2015 4:05pm
Happyoldgit
I once had a set of wheels and tyres that caused a wobble at certain speeds, no amount of balancing, changing wheel positions, rebalancing and beads would cure it. To all intents and purposes the various components in themselves checked out ok. Steve.
http://forums.lr4x4.com
Post #474868 21st Nov 2015 4:10pm
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Could be a slightly warped disc?
But if it's intermittent maybe not, just a thought.
Does the shaking get worse on heavy braking? 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #474869 21st Nov 2015 4:14pm
Penguin
no shaking while braking, and only intermittent above 90km/h.
I'll check all nuts and bolts again. 28/02 - Loss of a good friend...
Post #474870 21st Nov 2015 4:16pm
ericvv
Post #474871 21st Nov 2015 4:18pm
Mo Murphy
Sounds to me like swivel preload is incorrect.
50 Shades of Pennine Grey
Post #474886 21st Nov 2015 5:01pm
Happyoldgit
So if it's not on the original set from the dealer I guess a question to ask is what wheel and tyre combination is giving the problem? Steve.
Post #474966 21st Nov 2015 10:54pm
Penguin
it is on the original set, only less frequent and less intense.
If it was the swivel preload, wouldn't I feel it more on the steering wheel? I'm pretty sure it's not the front wheels that are vibrating.
Taking it to the garage is an option, but missing the def for some day's is not Wink 28/02 - Loss of a good friend...
Post #475058 22nd Nov 2015 9:01am
Penguin
Could this be the cause?
https://goo.gl/photos/e15LcvBRDxHTV1fQA
Both sides were loose 28/02 - Loss of a good friend...
Post #476950 28th Nov 2015 11:12am
VeeTee
Netherlands
You mean the clamps on the steering rod, or tie rod? Sure!
How is the drive with them fixed firmly? Cheers, Vincent
MySite
Post #476953 28th Nov 2015 11:21am
Penguin
going to test now.
But thinking of it, If that could be the case, wouldn't I had the risk of pointing my front wheels to opposite direction? 28/02 - Loss of a good friend...
Post #476955 28th Nov 2015 11:24am
Penguin
After some visits to the dealer, who could not find anything wrong, except blaming it on bad calibrated wheels, I decided to replace the stock suspension with HD suspension.
Guess what: Problem solved.
This is how the front stock spring looked like when still in place:
As it is now:
Post #506884 22nd Feb 2016 8:02am
I Like Old Skool
United Kingdom 1994 Defender 110 300 Tdi ST Coniston Green
Sounds like you had a lazy damper then or a worn bush that has either been replaced during the install or tightened up by the change in suspension geometry.
Post #507214 23rd Feb 2016 8:54am
ericvv
Penguin wrote:
Remember you said you would have that lovely truck Dinitrolled?
Penguin wrote:
@Eric, I'm doing the dinitrol job at Gert Goverts.
Didn't happen I guess. Sad
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #507513 24th Feb 2016 4:24am
