![]() | Home > Td5 > Should I put this piece off metal back? |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3677 ![]() ![]() ![]() |
does that protect the hand brake drum from getting a smack ? DEFENDER 90 TDCI XS,
MT Member Since: 22 Aug 2014 Location: Scotland Posts: 38 ![]() |
Toss it in the skip, you will never notice the difference.
sharkey964 Member Since: 05 Oct 2014 Location: On a muddy track Posts: 584 ![]() ![]() ![]() |
There isn't one fitted to mine,bin it;I don't think you'll miss it.
think of it this way if you find that it need to go back after replaced every this else you will be under the land rover of another day removing brake drum and prop shaft again to fit it back on
It will stay off for a while. The handbrake has to come off anyway as I have to replace the cable. I had the wrong one ready to go under
![]() So it is not the seal around the input shaft, And it is not the middle shaft that comes through the housing but it comes somewhere from there. And yes it come out off the transfer box as that level is dropping more then half a litre over 400km so a little more then 200 Mile. The search continues. ![]() ![]() 1984 90 2.5 na Diesel - RR V8 (1994-2001) 1997 Camel Trophy Discovery 300TDI (2001-2009) 2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts. 2003 90 Td5 (2009-now) |
