Home > Tdi > Main beam dash light flashing. |
What were the lights themselves doing:? Was there any relay 'chatter?' It could be the relay itself or you have a short circuit behind the dash or.......
We could theorise all day. A few more details if possible may help to nail it down perhaps? If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
20th Nov 2015 12:26pm |
Had this before on a different vehicle and it turned out to be the stalk switch itself.
Solution was a new stalk. |
20th Nov 2015 1:00pm |
MuddyChris300tdi Member Since: 02 Mar 2014 Location: Derby Posts: 224 |
The lights themselves, from the reflection from the car in front weren't flashing, just on as dipped beam which they were switched on as. I didn't notice any clicking from a relay. It's constant flashing when on first and second position on light switch. I have Googled but haven't come back with anything.
20th Nov 2015 1:14pm |
Last weekend my lights packed up, except main beam. I reomoved dimdip relay and replaced with cable from spade holes 2 to 8 and its been working fine. I will check that it is all in place.
20th Nov 2015 1:18pm |
Sorry it's not main beam at all its the light below it, any ideas what it is?
Click image to enlarge |
20th Nov 2015 1:41pm |
shaggydog Member Since: 12 Aug 2012 Location: Kent Posts: 3346 |
Below the Main Beam light should just be your sidelights/dipped beam on light.
Have a look behind it it may be the bulb on its way out though I have never known one to blow. Otherwise as Supacat says, check your stalk switch. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197 Self confessed mileage hunter |
20th Nov 2015 1:48pm |
red zepplin Member Since: 26 Mar 2015 Location: Never far from a brew (Lancashire) Posts: 196 |
i'd have a look at the switch if the relay apprears ok they are prone to "burn out" especially if your running extra lighting dlr's ect
20th Nov 2015 4:57pm |
So is that light ment to be on with side lights. Its never been on until now.
20th Nov 2015 9:04pm |
Its meant to come on when you select side lights and remain on when you select dim beamed lights. Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
20th Nov 2015 9:22pm |
