Home > Maintenance & Modifications > Would anyone recommend WHEEL SPACERS?
mcmen
Hi all,
Thinking about putting on some wheel spacers to make my car look wider and have more presence.
Have any of you carried this out? Does it make much difference? Which ones to buy?
If so, would greatly appreciate pictures. [/u]
Post #473438 17th Nov 2015 12:21pm
K9F
Hi mcmen,
Probably due to human nature most people that have them (and there are a few) would recommend them. A due consideration perhaps is that a decent offset wheel would give you the look and stance you are after without the need for spacers. There are many threads on the subject matter and here are a few of the choice ones.....
Best ones to buy.
http://www.defender2.net/forum/topic16778.html?highlight=spacers
Do I need them?
http://www.defender2.net/forum/topic36745.html?highlight=spacers
Alloy wheel spacers.
http://www.defender2.net/forum/topic35317.html?highlight=spacers
Fitting wheel spacers can also create issues....
http://www.defender2.net/forum/topic32739.html?highlight=spacers If you go through life with your head in the sand....all people will see is an ar5e!!
Post #473517 17th Nov 2015 4:17pm
Wild Card 90
England 2012 Defender 90 Puma 2.2 SW Indus Silver
Yes they (30mm per side) make a difference. Increased wear on the swivels, steering rods and wheel bearings, and more dirt up the sides of the body are the downsides. Looks, less roll and the opportunity to dial in a tighter turning circle at full lock is the good news.
Putting them on is about as sensible as buying the Defender in the first place..... Laughing
I have them on mine, behind already wide 7 x 16 CW alloys, and it drives fine. Wouldnīt be without them.
The MUD "dirt defenders" deflectors behind the front wheels help to keep the dirt in check.
Stephen 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
2" raised Trailmaster/Terrafirma
Heavy Track Raids, 255 MTīs,
Recaro CSīs, anorak, wellingtons
Post #473531 17th Nov 2015 4:59pm
K9F
As stated a decent offset is probably the better option IMO. Neither have spacers fitted.
Post #473533 17th Nov 2015 5:03pm
jst
i have some for sale! Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #473535 17th Nov 2015 5:04pm
Wild Card 90 wrote:
... Increased wear on the swivels, steering rods and wheel bearings ...
I challenge you to produce a shred of evidence that 30mm spacers added to otherwise the same wheels and tyres makes the slightest difference to any of those!
The difference produced by 30mm spacers is utterly negligible - a fat driver will have more effect on hub loadings!
There is of course also no difference in hub loadings between a 30mm spacer and a wheel with 30mm less offset.
My personal preference if you want spacers is to buy those manufactured by Rakeway. Not the cheapest, but you will have no quality issues and no balance or alignment issues with them.
And yes, they do allow your tyres to plaster the outside of your vehicle - and the inside if you have the window open - with crud!
Post #473536 17th Nov 2015 5:08pm
DonH2000
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Santorini Black
I had some Rakeway 30mm spacers fitted to my Discovery 1 and I noticed not a lot of difference to daily driving. Looked good though!
Just a thing to note when Porsche launched their new 911 spider a few years ago that too was sold with spacers!!!! Makes you think! Cheers Don.
Post #473549 17th Nov 2015 5:41pm
stew 46
England 2010 Defender 110 Puma 2.4 USW Bonatti Grey
Got 30mm on my disco 3 , and they look and feel great Thumbs Up
Post #473558 17th Nov 2015 6:20pm
JOW240725
James (JST)
I should probably let mcmen have first dibs, but PM sent. Smile
Post #473565 17th Nov 2015 6:39pm
fathaggis
yes 30mm on my 90 and soon the 110 Thumbs Up
Post #473569 17th Nov 2015 6:45pm
geobloke
Yes I have them on my 110 and had them on my previous 90. 10 years or so now with no bearing related issues. Not been through any more ball joints than expected neither.
What I will say is make sure they are tightened up to at least FT...
The improved turning circle on the 110 is worth the cost IMHO.
Post #473615 17th Nov 2015 8:35pm
Stacey007
I would like them purely for looks.
2 things niggle me having them...
1) My insurance will go up around Ģ50 and given I only paid that to have a Brabus performance box of tricks on my last car it sounded quite a lot.
2) I'm not sure I read this right but if I decided to go on an off road day using my car some organizers don't allow then?
Post #473619 17th Nov 2015 8:44pm
jst
point 2. AWDC hvae limitations on spacer widths - 25mm i believe. Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #473662 17th Nov 2015 9:42pm
Pickles
Wouldn't use 'em on any car, ever.
They are illegal in Australia.
Spacers place more stress on all suspension componants, which is why they are illegal in Aus, & totally frowned upon by insurers.
Pickles.
Later!!!...Thought I'd better add,.....I know the situation in the UK is different, I know you guys have no such restrictions,.....I wonder why that is?
Post #473669 17th Nov 2015 9:51pm
Wild Card 90
Happy to accept I have no evidence of shortened life of said components, and am clearly prepared to accept the additional wear if it does become apparent.
I didnīt have spacers on my TDi with Boosts, and replaced the track rod ends after about 50000 miles as the steering was getting a little sloppy. Did do quite a bit of wading around in the mud in that one.
So hereīs a couple of pics of mine, with said 7x16īs, 30mm spacers and 255/85īs.
 1998 Tdi 90 SW,
2008 Td4 90 SW,
2012 2.2 90 SW,
Post #473671 17th Nov 2015 9:51pm
