Home > Maintenance & Modifications > Aerial Hole
Silver Back
United Kingdom 1998 Defender 110 300 Tdi HT Coniston Green
Aerial Hole
Evening all,
I'm going to bring the 110 hardtop into the 20th Century and fit a radio, or should I say wireless! Laughing
Currently, there's no hole in the wing for the aerial, and as I'm likely to fit some chequer plate in the future, I want to get hole in the right place.
Would someone be kind enough to measure where the hole is on a standard wing? 300tdi so aerial going on the off side wing.
Thanks everyone. Thumbs Up
Andy
Post #472894 15th Nov 2015 11:10pm
dave18
United Kingdom 1984 Defender 110 300 Tdi CSW Portofino Red
Why not get the chequer plate and use that as guide to make sure its 100% or get the wing tops with no hole and then add it where you need it !!
Post #472898 15th Nov 2015 11:13pm
Jonno1968
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Orkney Grey
I have a set of chequer going free if you want it as a guide or to even install! It's aluminium, slightly discoloured but some sort of solvent would get it new again I am sure. Pm if you are interested.
Post #472913 16th Nov 2015 12:03am
T1G UP
why not leave the hole or buy checker plate with out the hole and mount an aerial inside?
Post #472925 16th Nov 2015 12:19am
