Home > In Car Electronics > quick bluesea box question |
g-mack Member Since: 07 Jan 2014 Location: northumberland Posts: 1967 |
what size terminal are the + & - posts? 5mm 8mm? just need to get some ring terminals bought My 109 thread
my youtube channel |
13th Nov 2015 3:05pm |
apt100 Member Since: 05 Mar 2015 Location: Derbyshire Posts: 1547 |
I think the details are on the website, if it helps .... https://www.bluesea.com/products/5025/ST_B..._and_Cover
13th Nov 2015 4:23pm |
**Edit** Snap!
https://www.bluesea.com/products/5025/ST_B..._and_Cover If you go through life with your head in the sand....all people will see is an ar5e!! Treat every day as if it is your last....one day you will be right!! |
13th Nov 2015 4:26pm |
yep looked at that but I'm not techy and have no clue what #10-32 Stud is in mm's My 109 thread
13th Nov 2015 4:32pm |
NormanD Member Since: 12 Aug 2011 Location: Bristol Posts: 282 |
10 - 32 thread diameter is 0.190" (4.826 mm), therefore use a 5 mm Ring Terminal NormanD WE191
2015 110 XS Utility 2014 VW Caravelle 180 Executive |
13th Nov 2015 5:03pm |
Ramsay Member Since: 30 Sep 2015 Location: Moffat, Dumfries & Galloway Posts: 625 |
10-32 free fit is 17/64" which is just over 5mm so 5mm rings should work.
13th Nov 2015 5:05pm |
5mm it is thanks guys My 109 thread
13th Nov 2015 7:51pm |
