![]() | Home > Puma (Tdci) > 08 110 DCPU Springs |
Def90 Member Since: 17 Jan 2015 Location: Kent Posts: 268 ![]() ![]() ![]() |
Hi Phil_D
I take you just want to remove the heavy duty and replace with a standard duty rear springs? I would give Dan at Duckworth parts at call,he's very helpful and they are a site sponsor. He should be able to help you with the correct springs. Def90 |
Well the answer in the 2007 Workshop Manual is as follows:
RHD 110 7 seat station wagon (3050 Kg) Front - Both sides NRC 8045 Yellow/yellow Rear - Both sides RKB500300 White/green/green LHD 110 7 seat station wagon (3050 Kg) Front - Driver's side NRC 8044 White/white Front - Passenger side NRC 8045 Yellow/yellow Rear - Both sides RKB500300 White/green/green |
Phil_D Member Since: 09 May 2014 Location: Perthshire Posts: 25 ![]() |
Thank you, that was the answer I got from Dan but not from a local dealer!
Phil. |
