Home > Maintenance & Modifications > Range Rover Evoque front seats in a Defender?
Vanderbult
Netherlands 2011 Defender 90 Puma 2.4 SW Santorini Black
Hi i own a 90 from 2011 and i'm wondering if it is possible to fit Evoque seats to my defender?
I think the biggest problem would be the hight of the seating.
Does anyone have a clue on where to find the workshop manual for an evoque?
Cheers,
Rick
Post #470011 6th Nov 2015 11:13am
Grenadier
Wouldn't they be too advanced/technical and require some kind of link to a higher end ECU for the airbags, remote adjustment etc? Not to mention the price. I bet you they would cost more than even a pair of equivalent Recaros which we all know fit well.... Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #470041 6th Nov 2015 12:00pm
Mike_B
United Kingdom 2006 Defender 110 Td5 USW Java Black
A mate of mine has RRS seats in his defender. Wiring to the seat was pretty simple allowing all the adjustment to work. Airbag is still inside the seat but not connected so is in effect just ballast now!
Post #470056 6th Nov 2015 12:28pm
Vanderbult
You Thank it's possible to get some pictures of those RRS seats in a defender? Because I think the seat base of those seats are even higher.
I've done some research and all the electrical stuf is build in the seat, so all the movement would be possible if I wire up the 12v to the seats. Of course the airbag won't work though.
Post #470068 6th Nov 2015 12:56pm
Vanderbult
I don't like the look of the recaro's and there is a scrapyard close to where I live which is specialized in Range Rover parts, they have a couple of seats from crashed evoque's. Which I do like the look of, I think it's just a matter of hooking up the power to the seats since all the electricals are build in the seat.
Post #470072 6th Nov 2015 1:00pm
Grenadier
Pop along with a tape measure or even with your defender, as it takes only 10mins to pop the front seats out and you can lift the evoque seat in, and if someone holds it from behind, even practice sitting in it. Then you'll know not only that it fits, but if it 'looks' right... Thumbs Up Monsieur Le Grenadier
Post #470105 6th Nov 2015 2:48pm
Mike_B
I'll try to get some photos of the RRS seats in the defender..
Post #470617 8th Nov 2015 11:13am
Vanderbult
Thanks
Post #472114 13th Nov 2015 12:56am
Vanderbult
So turns out the seats are to wide. too high as well but the seat base wasn't that compact so i figured i could change that, but because the seat is so wide that the seating position changes to much towards the center of the car.
I've done some digging around and the best i could find that would fit are porsche seats and from a smart for two.
Post #472116 13th Nov 2015 1:01am
Eduardo
Try the seats of a Citroen Xsara Picasso...
No a Porsche one but if you are looking for comfort are OK
I seen some Defenders with those seats in Argentina.
Cheers Eduardo
Post #472128 13th Nov 2015 3:05am
Cheshire110
Personally I find the defender seats very comfortable... Cheers, David
Post #472133 13th Nov 2015 4:58am
ericvv
Think so too. Nothing wrong with those Recaros. Whistle Surely better than anything coming out of an Eeewok. Laughing You never actually own a Defender. You merely look after it for the next generation.
http://youtu.be/yVRlSsJwD0o
https://youtu.be/vmPr3oTHndg
https://vimeo.com/201482507
Post #472140 13th Nov 2015 7:07am
jesperjes
2002 Defender 110 Td5 DCPU Java Black (black Hood)
I have recently installed Mazda RX8 seats. Those are REALLY comfortable!
Post #472153 13th Nov 2015 8:29am
GUM97
Also, the seat control module on Evoque seats is coded to VIN, so will only work on that Evoque, it's not as simple as supplying a 12V feed. An engine to TDi for!
Post #472496 14th Nov 2015 6:29pm
