Home > Maintenance & Modifications > Axle stands
Axle stands
What have the rest of you got?
I haven't got any at all, but thinking I should soon in case I need some.
I've got springs etc to change soon, so not wanting to be try to do a job half heartedly just to avoid buying a pair for safety's sake.
Post #469305 4th Nov 2015 11:41am
ARC99
Posted this reply but it disappeared.
I have two sets . These https://www.machinemart.co.uk/shop/product...-020110000
and https://www.machinemart.co.uk/shop/product...-020110003 Don't make old people mad.
Richard
Post #469310 4th Nov 2015 11:55am
They are better value than I thought actually.
I've seen Bacho also elsewhere.
I would imagine Clarke to be pretty reliable
Post #469313 4th Nov 2015 12:09pm
Harry.O
I have the same set as the second link that ARC99 posted and cant fault them, they must be 8 years old and have always worked well. I also have a bigger brothers of those rated to 6ton and found the extra height was useful during a chassis-up rebuild.
Harry
Post #469314 4th Nov 2015 12:13pm
ARC99
reliable yes, the only problem I have had in the past, the blue set sinking into the tarmac outside the house. Don't make old people mad.
Richard
Post #469315 4th Nov 2015 12:13pm
Defender-Stu
Set of Draper ones for me and had the FFRR sat on them before and not a problem cost about £20
Post #469317 4th Nov 2015 12:20pm
K9F
The blue set I have had for longer than I can remember. Agree totally with ARC99 about the sinking into tarmac so I moved house and now have block paving!
Laughing Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #469318 4th Nov 2015 12:21pm
On tarmac I always use a board under a jack, axle-stand, or anything else which is supporting a significant load. 'Orrible stuff, tarmac!
Post #469324 4th Nov 2015 12:54pm
jimbob7
Generic 3 ton ratchet silverline/clarke/draper/halfords.....pretty much everyone including cosco,for less than £20.
http://www.ebay.co.uk/itm/HEAVY-DUTY-SILVE...3641.l6368 Pov.spec,ftw. 2006, 110,TD5.
Post #469332 4th Nov 2015 1:14pm
RRUK
I've just bought a 2nd set from Halfords. Non ratchet as I read these can fail. 3 tonne capacity for £17:50. They're very well built. 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #469340 4th Nov 2015 2:01pm
The area I'm using to park is a compacted fine grit. (Golden)
It's not concrete, tar or gravel and you could scuff a hole in it so indeed a board would probably be needed.
My biggest concern is anything slipping when spring changing so that is why when I do attempt it I'll do it properly or not at all.
I don't want it it myself in any way damaged that's for sure. Shocked
Post #469356 4th Nov 2015 2:33pm
RRUK
Look for ones with a solid triangular foot rather than 3 feet, it spreads the weight.A good board underneath should help too. Make sure there's some width around the foot on the board so it can't fall off the edge of the supporting board. 2016 D4 HSE
Post #469364 4th Nov 2015 3:14pm
I'm actually not a huge fan of axle stands, and although I do use them, for anything heavy duty, or for working underneath if I'm going to be hittng, rattling, or shaking anything, I prefer to use chunks of sawn-up railway sleeper, ideally hardwood,
Cut into blocks about 12 inches long, these can be built into really solid piles and will hold without anyrisk of the vehicle rolling and pulling them over, etc. They are ideal for putting under the chassis as they won't mark or bend it, or under the rear crossmember, etc.
They are not as easy to handle, take up more storage space, and there are times where you can't use them, but for me the block is preferable to the stand. And they don't sink into the ground either!
Post #469371 4th Nov 2015 3:49pm
Romadog
Halford's ones Thumbs Up
Had them for years and well made.
Post #469475 4th Nov 2015 7:53pm
strang
United Kingdom 2009 Defender 90 Puma 2.4 XS CSW Galway Green
They are not infallible though - an idiot can still have accidents....
[URL=][/URL]
Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated Mr. Green  Euro-Leafing to infinity and beyond.....
Post #469498 4th Nov 2015 8:31pm
