Home > Technical > Replacing Swivel seal with out stripping down!!??
dave18
United Kingdom 1984 Defender 110 300 Tdi CSW Portofino Red
Hey peeps, Noticed I have a seep coming from my swivel seal. REALLY dont want to strip everything down. Can I just remove the wheel then undo the Swivel from the axle and do it that way ???
I know there is the REME way of cutting the new seal at 45 deg then fitting it with the cut at the top which ive done before and worked for years.
Post #468433 1st Nov 2015 9:12pm
mse
Removed it all from the axel on the 300 Mike
Post #468440 1st Nov 2015 9:19pm
dave18
Sounds good to me Very Happy Very Happy Very Happy
Post #468445 1st Nov 2015 9:26pm
Merlin
Just take off the calliper and unbolt the whole unit pulling it out with the half shaft attached. 20 minute job.
Merlin
Post #469001 3rd Nov 2015 12:10pm
Mash
Guernsey 1998 Defender 90 300 Tdi HT Nato Green
As said take off the calliper and then undo the ring of bolts pulling the full assy including drive shaft out then you can swap on a bench, remembering to clean the disk of any oil on assembly.
The REME method was only do-able on the DAF 4t as it was a rubber seal only, the Land Rover one has a spring incorporated so can't be cut. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
90 V8 - Maggie http://www.defender2.net/forum/topic42564.html
110 TD5 - Buggsy http://www.defender2.net/forum/topic59029.html
52HG25 lightweight https://www.defender2.net/forum/topic72342.html
D3 Hse - Fiona
Capri 2l S - Anna
Think I might have a problem............
Post #469041 3rd Nov 2015 2:14pm
Mash
Another point I use a 14mm ring spanner with half of the ring removed as it grips the bolts once they have been cracked off a lot better than an open end. 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #469042 3rd Nov 2015 2:16pm
dave18
MASH I can confirm the REME method works on steel ones too Cool Wink Wink
Cheers for the info about the spanner, Is there no room for a ring spanner???
Post #469110 3rd Nov 2015 7:15pm
Mash
Haha I have never tried it and happy to do it properly on mine, as for the spanner you can get one in and a ratchet one fits great but once the blots are undone they butt up on the swivel housing and you can't removed the ring end without winding it back in.
Don't forget to replace the paper gasket on the swivel/axle joint on re-assembly (a job card can be cut lovely and will do a perfect job.....that's a nice REME trick) 90 wolf - Jasmin http://www.defender2.net/forum/topic39408.html
D3 Hse - Fiona
Capri 2l S - Anna
Post #469197 3rd Nov 2015 10:41pm
Happyoldgit
I've done it using the splitting method years ago but by either carefully removing the old seal spring or unwinding the join in the new spring and then rejoing it again once it's ready to go back in the new seal. Steve.
http://forums.lr4x4.com
Post #469226 3rd Nov 2015 11:59pm
dave18
Cheers peeps got new gasket and retainer on order with the seal.
Post #469233 4th Nov 2015 1:16am
