![]() | Home > Maintenance & Modifications > Noise Killer Insulation |
seriesonenut Member Since: 19 Nov 2014 Location: Essex Posts: 1247 ![]() ![]() |
Hi
Does anyone have any experience of Noise Killer roof soundproofing? http://www.nkgroup.co.uk/product/land-rove...m-egg-box/ I am fed up with a sagging headlining so am considering fitting the 25mm egg box insulation without the liner going back. The main issue will be getting rid of the condensation, hopefully this will not be an issue without the liner Thanks 1991 200 CSW 1958 S1 4x2 |
jeffersj Member Since: 23 Jan 2015 Location: Near Preston Posts: 431 ![]() ![]() ![]() |
Used the egg box stuff in the far of the hard top, easy to install and certainly works! Jeff
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5129 ![]() ![]() ![]() |
I have used noise killer products for years, always good quality and works. They are based at Royton
Oldham a couple of miles from the M62, if you ever visit them have a look in their skips for the off cuts of their products, (they do not mind) last time I went there I filled the back of the 90 up with off cuts some of them over a meter square all for free. ![]() http://www.youtube.com/user/conwy1 |
