![]() | Home > Maintenance & Modifications > heavy duty drive flanges |
| I Like Old Skool Member Since: 23 Feb 2015 Location: Manchester Posts: 886
Fitted aftermarket standard replacement flanges to my 300tdi 110 earlier in the year and they are the same for front and rear (disc braked Salisbury) axle. Can't see any reason why the H/D items would be any different.
| Chris86 Member Since: 15 Jul 2014 Location: South Yorks Posts: 804
Would the.easiest methodology check.not be to quickly take one off your other axle and try it?
Chris |
| MuddyChris300tdi Member Since: 02 Mar 2014 Location: Derby Posts: 225
I've fitted a set to my 130. I think there is only two options with them are thick flanges for early type axle and thinner ones for the later type axle. The the thinner ones were the correct ones for my 95 Salisbury Axle.
| swissoak110 Member Since: 28 Aug 2015 Location: cleveland Posts: 17
Thanks for your help guys, ordered some just now.
| All times are GMT |
