![]() | Home > Puma (Tdci) > Heather problem? |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2509 ![]() ![]() ![]() |
Everything is possible in a LR, but try gently with a wire in case somebody in the factory left an hankerchief. If not I guess you have to take the front dash out and aint easy. Puma 110" SW
LESVOSD110 Member Since: 19 Aug 2009 Location: South Africa Posts: 241 ![]() ![]() ![]() |
Hello,it is not normal.My friends puma had the same problem.I will ask if he fixed it. Puma 110 SW 90 V8 SOFT TOP |
There is a recall, call your dealer. Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition
![]() IID Pro MV License |
John051 Member Since: 13 Aug 2010 Location: Antwerp Posts: 24 ![]() ![]() ![]() |
The heather problem only occurs when the A/C isn't on. With the A/C the heat distribution is OK.
J |
JaffaTheNeste Member Since: 02 May 2010 Location: Helsinki Posts: 10 ![]() ![]() ![]() |
Hello!
Have the same problem here, driver side gets annoyingly hot and passengerside warm or cold. I am running out of warranty in a few months, i was just at my dealers for clutch rattle and some recalls. They said this heater problem is not fixable, and that there are no recalls for this? ![]() I'm not the only one in Finland with the same problem. |
Call your dealer and "SCREAM" him SSM39653
http://www.defender2.co.uk/gallery/albums/...er_fix.pdf Discovery 5 td6 HSE Stornoway Gray Outback Engineering Limited Edition ![]() IID Pro MV License |
johnnyturbo2002 Member Since: 21 May 2009 Location: Poniente Granadino Posts: 371 ![]() ![]() ![]() |
Did you ever get this fixed? What was the final response from the dealer? 2008 Defender 110 60 year Edition (sold unfortunately) IN the hunt for another Puma for the wifey! 2008 Kia Sorento LX 😁 2.5crdi |
![]() ![]() ![]() ![]() Treat every day as if it is your last....one day you will be right!! |
Hey,
Past by the dealer a while ago and they will check it out during the 1st service. I played with the cold/warm air dial and when past a certain point on the dial the distribution is normal ![]() Gr, J |
AndrewS Member Since: 10 Apr 2007 Location: Hereford Posts: 3711 ![]() ![]() ![]() |
Dash out is not that bad takes about 15 minutes
![]() ![]() ![]() Click image to enlarge 130's have feeling's as well you know ![]() |
