![]() | Home > Td5 > Tail indicator lamp seal gasket part number? |
RF3777 Member Since: 10 Apr 2015 Location: Hong Kong Posts: 144 ![]() ![]() ![]() |
![]() I recently bolt on something new to my TD5 tail, they are easy mod! but then I discover one tail light has lost the seal, I've been trying to look for the part number, but no luck... Anyone knows that parts number? or it comes with the lamp kit? ![]() |
Podrob Member Since: 20 May 2012 Location: Co Derry, N Ireland Posts: 31 ![]() ![]() ![]() |
Think it comes with the lamp but could use foam draft excluder or similar
Doesnt seems to have one
![]() ![]() Click image to enlarge |
Did it with a piece of thin rubber!
![]() Thanks |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2236 ![]() ![]() ![]() |
As above, I've made one out of parcel packing/packaging foam in the past. A piece of cheap and nasty rubber car mat will also do. Make it slightly smaller diameter than the lamp holder, and smear a bit of RTV silicon or similar on both sides. ![]() |
Actually, forget that....
Get yourself a nice set of LED lights and the new gasket comes with them! ![]() |
LED light outside of Defender is illegal in H.K.!!!
Oops sorry!
![]() That's unlucky ![]() I should have thought about that. ![]() I do wonder why though....... |
Defender is register as commercial vehicle(Van), because its diesel power, need annual inspection!
if the LED are not original come with the car, its illegal! anything might cause accident will not be accepted in the vehicle, includes big screen radio unit! ![]() |
