![]() | Home > Td5 > Internal lighting question |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17922 ![]() ![]() ![]() |
The interior light is permanently live, and the switches provide a ground connection. If the light works from the manual switch, then there is power to the light.
It is not inconceivable that all the door switches have failed, though it seems odd that they have failed all at the same time. Firt thing I would do is unscrew one of the door switches from the pillar and manuall ground the wire going to the switch to a known good grounding point. If the light comes on, the fault is the switches. If the light doesn't come on, it's time for a rethink. (Edited for spelling) Last edited by blackwolf on 16th Oct 2015 1:49pm. Edited 1 time in total |
alexatnd Member Since: 19 May 2015 Location: Yorkshire Posts: 292 ![]() ![]() |
Sounds like a plan, as soon as I've put the started motor back in after renewing the brushes ..... Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
Gertie - 1999 110 TD5 - new chassis etc back on road Effie - 2004 110 TD5 County |
None of the door switches worked hen I got the car so its possible they died 1 at a time .. Santa - 1977 Series 3 - new chassis, tub, disc brakes,SU Carb
