Home > Wheels & Tyres > 255's at full articulation
RCMike
Hi All,
I thought i'd share a picture of my new 255/85/16's at full articulation just in case anyone considering this size wonders how they fit at full unrestricted articulation.
The wheels are zero offset and i needed extended bump stops (actual extension is 1" over standards) to stop possible rubbing at the top inner edge of the plastic wheel arch extension. With this, there is about 10mm clearance.
Post #463728 16th Oct 2015 10:33am
g-mack
that is tight, i presume front is OK? My 109 thread
my youtube channel
Post #463732 16th Oct 2015 10:44am
RCMike
Yep, the front is OK. Even without an ARB at the front, it doesn't articulate as much as the rear. I've not extended the front bump stops as the axle doesn't reach them and there is a lot more room anyway. Also no trimming required at the front.
Post #463737 16th Oct 2015 11:08am
Chris86
United Kingdom 2005 Defender 110 Td5 USW Chawton White
Have recently fitted the same set up to my 05 110, mine just clip the inside edges of the front arches as well on full bump/full lock. I need to trim a touch more out of the back of rear arches too I think although I don't think I'll need to trim quite as much as you have- mine somehow seem to 'tuck in' more?
Fitted 255/85/16s to a friend's truck earlier this year on boosts. His fouled the rear spring seats on near full bump at the back-so fitted spacers
Chris
Post #463755 16th Oct 2015 11:55am
RCMike
Perhaps mine need's to loosen up a bit at the front.
Post #463763 16th Oct 2015 12:35pm
I had to trim the inward-facing lip off the front lower corner of each rear flare on my 110. I did the rear lower corners too. My 255s are on Blindos with a 14mm positive offset, and I haven't had any other contact issues.
I am however not optimistic about compatibility with tyre chains - I think that any attempt to use them would rip the flares off the vehicle and enlarge the arches is a rather raggedy manner! Big Cry
Post #463769 16th Oct 2015 12:43pm
couplands
United Kingdom 2001 Defender 90 Td5 HT Oslo Blue
I have 255's on Freestyles (same offset as Boosts I think) and they are fine with standard suspension on my TD5 HT. No rubbing anywhere. ARBs have been removed.
^^^agree that chains would be a very tight/interference fit...Wink
cheers
simon
Post #463856 16th Oct 2015 7:00pm
Mdm
i think a lot depends on what wheels you use
the recommended size is 8 inch for best results
boosts are 7" ?
i used to use this size a few years ago and have gone back it to last year on a 2 inch lift without any issues
Post #463898 16th Oct 2015 9:42pm
RCMike
Almost forgot to post a pic of the front's under full compression with the 255's (well almost - the axle was about 5 to 10mm from the bump stop). Looks very tight but still room without rubbing.
Post #500641 4th Feb 2016 10:35pm
