Home > Technical > Indicator problems (x2) |
BigRuss Member Since: 15 May 2010 Location: Norfolk Posts: 2785 |
Sounds like it's either the switch or a loose wire.
But I bet you can't buy the switch without the stalk! |
21st Sep 2010 9:14am |
o4dn Member Since: 08 Jan 2010 Location: South West Posts: 530 |
Here, the trailer light comes up briefly when indicating, it does not flash though. It's been like that with both Defenders I owned so I deemed it as "normal". |
21st Sep 2010 9:17am |
leeds Member Since: 28 Dec 2009 Location: West Yorkshire Posts: 8578 |
Think know the solution to (1)
ARB winch bumper fitted which has repeater indicators on! Dooohhhhhhh! I will never make a mechanic! Brendan |
21st Sep 2010 9:23am |
dm_td5 Member Since: 20 Jul 2008 Location: Arnhem Land Posts: 609 |
As for (1) the trailer indicator flashes once if nothing is connected to the trailer socket (whether fitted or not). If you fit a bullbar with indicators it adds an extra bulb to the indicator circuit, just like connecting a trailer does. The flasher circuit detects this extra current and this causes the trailer lamp to flash as well to tell you the trailer indicator is working.
Two easy solutions: (a) replace the bulbs with 5W ones in the bullbar or (b) put LED bulbs in the bullbar indicators. This will stop it happening. Of course the other thing that happens is that if you attach a trailer with LED lamps the trailer indicator doesn't flash for the same reasons as above. As for (2) no idea 110 2.4TDCi 110 300Tdi LROCV ::: AULRO.com |
21st Sep 2010 9:38am |
Paul_1978 Member Since: 08 Nov 2009 Location: South Yorkshire Posts: 384 |
Sounds like the switch on issue 2.
The switch/stalk sets are on ebay all the time, i think you have to remove the steering wheel and set up the automatic off function when re fitting the new one. Its simple, just set the blue dial to the centre before refitting the steering wheel. |
21st Sep 2010 11:57am |
expedition Member Since: 11 Sep 2009 Location: Vercelli-ITALY Posts: 75 |
I purposely removed the blue circle that leads back to the arrows in his place, I feel very good. Vale
110 Td4 MY07 "E" Keswick Green |
21st Sep 2010 12:22pm |
