Home > Maintenance & Modifications > Spacer on which diff guards please ?
Daisy90
United Kingdom 2001 Defender 90 Td5 SW Alveston Red
Evening,
Collected loads of metal bits from the powder coaters today, super job they have done also,
I have front and rear wraparound type diff guards from bearmach,
One came with a spacer that has to be used for a puma truck,
Anyone know if it goes on the front or rear please ?
One less thing to work out tomorrow Wink
Post #462153 10th Oct 2015 9:09pm
Simon27
Scotland 2009 Defender 90 Puma 2.4 SW Tamar Blue
When I got mine the spacer came with the front one, (also came with longer bolts, which made sense).
Let me know how you get on with the rear one, I've still to figure out what bolts I need as mentioned here: http://www.defender2.net/forum/topic40547.html
Post #462162 10th Oct 2015 9:28pm
Probably for the rear diff due to close clearance of diff guard lip to the rear prop flange.
This was the case with QT's.
Post #462164 10th Oct 2015 9:34pm
Daisy90
Thanks folks, I
Ll let ya know my finding tomorrow Thumbs Up
Post #462169 10th Oct 2015 9:45pm
Devon-Rover
United Kingdom 2014 Defender 110 Puma 2.2 USW Aintree Green
Hi.
A spacer was supplied with standard rover rear wraparounds for use on Discovery models that have the rotorflex (Rubber Doughnut) prop coupling. The front ones shouldn't need the spacer and should clear the track the rod easy and it's design is no where near the flange
The Rear guard for the Puma (AKA P38 Short nose) is very close to the prop flange but the nature of the fixings means next to no adjustment to it.
Simon. The threads in the bottom of the diff casing are 3/8 bsf just that they are prone to corrosion you can see if you can get hold of a Tap and run it through to clear the threads or if you have a spare bolt you can make your own. Look up DIY or Inexpensive thread chaser bolts.
If you have any other questions just ask.
Post #462178 10th Oct 2015 10:37pm
