![]() | Home > Maintenance & Modifications > Led indicator problem |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20978 ![]() ![]() |
Most likely earthing in my experience.
Check, remove, clean and re-tighten Earth to chassis straps and bolts. Especially the rear. |
BuckBlu110 Member Since: 19 Apr 2014 Location: in the pub Posts: 735 ![]() ![]() ![]() |
Oh I do love earths
Small update on this, whilst fitting led bulbs to the dash, I've encountered an interesting turn of events, fitted the indicator warning bulb, and now when indicating right, the indicators flash as they should, except the passenger side still flashes, but very dimly, more so than before. When indicating left, all indicators work as they should, so the right side doesn't light up at the same time, but the dash light doesn't flash now.
So could this mean that the earth in the passenger wing needs looking at? |
You really want a multimeter to check for continuity of earthing.
You can also try temporary / jury earth to identify the problem. Then you should be able to do a permanent fix. I think the problem is probably a shared earth so not near the lights themselves but a common earth hence the flashing of unwanted lights. On a Puma the earth strap is on the transfer box, not sure on a 300. If you have a tow socket in good order you could identify the earth pin and link it to a good chassis earth temporarily. ( make sure it's insulated from other terminals. As its a common earth see if it does the trick. If it does then you'll need to search for the earth to chassis strap and there are often a few underneath. |
Thanks for the help, I'll have a look at the continuity, probably before that, locate any hidden earths. Could do with a indicator circuit diagram really. I'm wondering if there's an earth for this hidden behind the dash.
ian series 1 Member Since: 17 Nov 2014 Location: south Posts: 3127 ![]() ![]() ![]() |
I've just had an earth problem affecting all the rear lights/indicators
http://www.defender2.net/forum/topic40439.html Check the earth point on the right hand side of the transfer box. This earth point is responsible for lots of swearing/tantrum throwing....... ![]() ![]() Wanted, Forward Control Anything considered. |
Another update, I noticed the dash light for the indicators/hazards wasn't working, (it worked fine yesterday!) I removed the led and fitted the original bulb, now the light flashes and operates as normal when using the indicators, but doesn't flash when the hazards are on. Ive been through most of the earth points too and the original problem still persists, although there are a couple left to check out. Could this still be earth point related?
Ruddy electrics! ![]() ![]() |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5139 ![]() ![]() ![]() |
This is a known problem on a 300Tdi. And there is a fix, firstly take out the instrument flasher warning bulb, easy to do just undo the two screws on the warning light cluster and remove the little bulb. Next try your indicators with the warning light removed right and left they should work perfectly, if this is the case it will be due to an earth return through the loom from the indicators to the warning light (which it will be).
If all works with the warning bulb removed then you will need to phone up Bolt on Bits and just say I need the fix for my LED flashers on my 300Tdi Defender, they will immediately know what you are talking about and will sell you a new style warning bulb that has an earth lead attached, just connect the lead to a good earth and then put the new bulb in the warning light cluster and the job will be a good un! And everything will work as it should. Bolt on Bits do not sell this fix through their Ebay store you have to phone them up to order the part their number is 01274 688 388 For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
Thanks gilarion, I'll take a look
gilarion, you are a saint, looks like you were right, I've removed the bulb and now all is well, apart from obviously no dash light, so looks like I'll be getting contact with BoB on Monday and sorting out a earthed bulb
![]() Thanks!!! |
Glad that I was able to help. Note. The bulbs that Bolt On Bits sells although it looks the same as the original with the exception of the earth lead! The new bulb can on some clusters be a little stiff to insert, but it will go in the slot just use a tiny bit of force and it will twist in, the extra force will not break anything. Personally my advice would be when you have the time, I would cut off the dummy male bulb connector from the bolt on bits side repeater, cut off the female part of the bulb holder that sticks out of the wing and hard wire the side repeaters as I have heard that some people who have fitted them say over time the dummy bulb connector works loose. Make sure if you do this that the wiring is connected right as they are polarity specific Red to green white to black if I remember correctly. But do check to make sure. For those who like Welsh Mountains and narrow boats have a look at my videos and photos at.. http://www.youtube.com/user/conwy1 |
Cheers gilarion, I'll keep that in mind. I was thinking of changing the connectors to the plugs that are used on the side lights and other indicators. The male 501 fitting is the only bad point about these RDX side repeaters.
Ramsay Member Since: 30 Sep 2015 Location: Moffat, Dumfries & Galloway Posts: 633 ![]() ![]() ![]() |
Thanks for the steer gilarion. I am well on with sorting out my indicator issue with LED lights. 1995 Defender 110 CSW
1971 SIIA Lightweight |
