![]() | Home > In Car Electronics > Focal Subwoofer - Location? |
custom90 Member Since: 21 Jan 2010 Location: South West, England. Posts: 20978 ![]() ![]() |
Some also use the the rear of chubby box.
charliebaja Member Since: 05 Aug 2013 Location: Surrey Posts: 211 ![]() ![]() ![]() |
So I have a Focal IBus fitted and like you was unsure as to where the best place to fit it was, however i have now fitted it on the rear box arch snug against the side. It has a purpose made box which sits over it for protection and is Dyna matted and carpeted. Sounds awesome without any reverberation. Now if only I could get the rear speakers to work that are plugged into it!! Photo to follow.
jonnyboy Member Since: 15 Oct 2014 Location: Wiltshire Posts: 161 ![]() ![]() ![]() |
Steve - Surely its too big for the rear of the cubby. The Alpines, Kenwoods etc seem to fit there but this is much bigger
Charlie - look forward to the photo ![]() |
What sort of dimensions are we talking?
Unless we are talking REALLY big even if it is larger than the chubby rear you can likely make a mounting plate / board. But yes, depends on size though.. |
The Focal unit is much bigger than the, say, commonly fit Alpine unit.
The Focal is 344mm x 250mm The Alpine SWE 1200 is 280mm x 226mm and is a good fit on the rear of the cubby |
So after a bit of playing this afternoon, think I'm going to go for mounting it below the Cubby Box. Going to make an open ended MDF box, bolt that to the floor, install the subwoofer in that, and re-install the cubby box on that. Box will be about 4" high, open front and back for ventilation and maybe painted black/trimmed in vinyl
Anyone see any flaws in that? |
Sounds good. What gap between the chubby bottom and sub grille p?
About 1". Figure its designed to go under a seat.....
Yeah, that should be fine. Any less though I wouldn't go for.
It should transfer bass to body quite well. ![]() |
Edzi Member Since: 20 Sep 2015 Location: London Posts: 279 ![]() ![]() ![]() |
Would love to see some pictures please ![]() |
Edzi
Went for under the rear seat in the end.... http://www.defender2.net/forum/topic41292.html |
Thanks
