![]() | Home > Puma (Tdci) > Potentially Stupid Tow Ball Question |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17915 ![]() ![]() ![]() |
That part number appears to be for a simple standard towball only. In order to fit one you will need one of the several mounting brackets which are available for Defenders.
You basic choice is between a fixed mounting (which may offer several alternative mounting heights, but everything is bolted on so cannot easily and quickly be adjusted) or an adjustable type, where a ladder-like device is bolted to the crossmember, the ball is mounted on a detachable plate, and the plate is pinned to the ladder at the appropriate height for the trailer you want to move. Easily and quickly adjustable, and you can remove the slider with the ball to prevent theft or stop you whacking your shins on it. This type is, inevitably, more expensive. Fixed type: https://www.defender2.net/gallery/albums/userpics/11568/photo.JPG Adjustable type: http://www.pfjones.co.uk/images/detailed/8...6_7000.jpg If you want a simple, versatile setup for the sort of things you mention, which is future-proof against a possible later requirement to tow a trailer, either would do. If you anticipate a need to move things using a rope or chain, you'd be better of with a coupling that combines a pin/jaw coupling with a ball, such as one of these:- http://www.all-about-the-home.co.uk/ekmps/...3995-p.gif (Note these photos are just the first ones that a Google image search has produced, I am not endorsing suppliers etc). Hope this helps. |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6698 ![]() ![]() ![]() |
That part is just the ball itself, a bracket/plate is needed as well.
New take-off tow bars brackets come up on eBay, and there are aftermarket versions available from the likes of Witter, Britpart etc. I have a Witter R28 on my 15MY 90. Be aware that 110 and 90 tow bar kits are not the same (the tie bar arms are different). ![]() ![]() |
