Home > Td5 > Constantly Going into limp mode |
110MGD Member Since: 17 Oct 2013 Location: Wear Valley Posts: 153 |
As much as I love my old 90 I Am totally losing confidence in it at the moment.
At least one in five times I drive it the EML light comes on and I have no throttle control and have to limp it home or get a recovery out. This is extremely frustrating at quite frankly at the moment I could sell my daily car, and the defender and by another big modern 4x4 or perhaps even go Japanese (X5,Touareg, Land Cruiser, Shogun) as I am losing confidence in Land Rover However I love the defender and really want to keep it. Does anyone know a definitive list of what could be putting the EML light on? I thought I had cured it with a new fuel filter and the water in fuel sensor disconnected. What other things should I check Regards 2001 Td5 CSW (weekend and snow mobile) Plenty of lights, M/T tyres EGR delete, roofrack, swing away wheel carrier, snorkel. 2016 E220 CDI Night Edition Estate 2014 VW UP! 2x D3 and 1x D4 GONE |
21st Sep 2015 8:26am |
derbywill Member Since: 25 Mar 2010 Location: Derbyshire Posts: 540 |
Ideally you need to plug into a diagnostic machine to read the codes but is sound like a throttle pedal wiring fault, most people use five core wiring to bypass the original loom from the pedal to the ECU, not to big a repair and definitely not something to make you lose confidence as its a easyish one to sort.
Kind regards Will 2005 90 XS 1954 86'' Series 1 tilt |
21st Sep 2015 8:57am |
To save yourself a whole load of heartache it really needs to have a diagnostic kit plugged in. There might be someone in your area who'd be prepared to meet up and plug theirs in or give a good independant garage a call. Otherwise you could be chasing a simple fault round at great expense plus the time wasted.
21st Sep 2015 8:58am |
Daisy90 Member Since: 01 Feb 2015 Location: Hampshire Posts: 843 |
Mine did similar, more and more often, usually on a wet day,
I checked the loom from everywhere I could see it, including using a jet wash on the connectors and wiring, but could not reproduce the fault, So as a fix / elimination I also required the pedal and bypassed the loom untill it went into the ecu, I used trailer cable, Since then never missed a beat So although I have never found the problem it appears cured |
21st Sep 2015 5:01pm |
Thanks for the quick response guys. Doesn't sound too bad then, was sick as a chip and utterly annoyed with it before. Maybe I won't be so hasty now! 2001 Td5 CSW (weekend and snow mobile) Plenty of lights, M/T tyres EGR delete, roofrack, swing away wheel carrier, snorkel.
21st Sep 2015 5:52pm |
