Home > Td5 > Rear Window Heater
Simali
United Kingdom 2004 Defender 110 Td5 CSW Zambezi Silver
Rear Window Heater
Hi
The rear window heater on or 2005 110 isnt workiing. I have checked fuse 32 all good. Tested for voltage at the rear nothing. The light on the dash comes on ok. What else can i try ?
Post #456691 21st Sep 2015 6:41am
ian series 1
United Kingdom 2008 Defender 90 Puma 2.4 CSW Bonatti Grey
Probably one or more elements on the glass has worn away, or broke?
The high level brake light cover can rub through.
Try testing at the contacts on the window with a multimeter to find the break.
You can get heated screen repair paint to fill in the gap.
Quite a common problem on the Defender I'm afraid.
Sorry, just noticed, you have no power!
Try looking or testing wires where they pass through the loom from body to door.
You may have a broken wire somewhere? 80" 80" 86" 88" 90"
Wanted, Forward Control Anything considered.
Post #456693 21st Sep 2015 6:52am
caterham6
United Kingdom 2010 Defender 90 Puma 2.4 XS CSW Santorini Black
Mine same...William's stated MOT failure so I hard wired to black cable used rubber seal glass for cable support works well.
Post #456701 21st Sep 2015 7:15am
Loz2286
I have only one element working on mine. Are new screens available? From my series experience I know swapping the glass is easy but does the high level brake light come off? 1999 Td5 110 CSW
1961 Series 2 88 LPG
Post #459115 29th Sep 2015 9:24pm
rallysteve
Check the wiring inside the flexible rubber which leads from the rear body to the door. Often fatigue and snap. 02' 110 TD5 Double Cab Rebuild Thread
Post #459127 29th Sep 2015 9:52pm
Simali
Ta Steve turned out to be a broken cable in the rubber tube
Post #466580 25th Oct 2015 11:57pm
