Grockle
Thanks, Bell Auto Services | |
Rang last week ref cutting out problem, Pete knew straightaway, vac valve on the back of fuel pump
Thanks again for your time,
Rog. 2.4 90 XS
1968 1/32 scale Britains 109 Pick up.
20th Sep 2015 10:09am |
AlanH
I think that's the same valve I've ordered a replacement for. Called by several names including Suction Control Valve. My 2010 2.4 has had this horrid surging especially when cold on the mornings first run, foot off for the corner and it surges and nearly cuts out. Try to balance revs and braking at the same time as changing gear etc. Also a strange "wow wowing" (only way I can describe it ) sort of light noise at certain throttle positions.
Hopefully this'll fix the damn thing.
AlanH.
30th Sep 2015 9:19am |
