Home > Technical > How to Remove Front Grill
Mach1
United Kingdom 2015 Defender 110 Puma 2.2 XS DCPU Aintree Green
Stupid question because I am completely incompetent when it come to these things.
How do I remove the front grill clips without breaking them? I can't find anything on the internet so it's either impossible or so easy there's no way any idiot can't work it out!
I am that idiot.
Post #456483 20th Sep 2015 7:37am
Mjibex
United Kingdom 2013 Defender 110 Puma 2.2 XS CSW Loire Blue
I pushed them out with something flat from behind. You have to be slow, steady and push squarely.
They will be reusable if your carefull and they haven't been out too many times.
Post #456484 20th Sep 2015 7:43am
RRUK
It's easier to remove the grille panel if it's an air con model.
A screw on each side plus four at the top, then you can attack the little fir tree Censored ! 2016 D4 HSE
1982 Series 3 SWB Petrol
Post #456502 20th Sep 2015 10:01am
YOLO110
Australia
I took the grill off too! Much easier to get at the 'trees'...
What are you planning! Exclamation YOLO... You Only Live Once...
Post #456529 20th Sep 2015 12:29pm
