Home > Technical > steering wheel vibrating at 90 km/h
lrmaniac
Portugal 2010 Defender 110 Puma 2.4 DCPU Keswick Green
Hello
I’m having a problem, since I fitted the new wheels and tyres… (pics in this thread http://www.defender2.net/forum/topic3798.html ). Before I had these, the car behaviour was impecable!
When I fitted the wheels and tyres I went home slowly due to traffic … next day I attached a trailer with a boat on it and went on vacation … Because I could not drive above 80/90 kmh I did not noticed anything… Next day without the trailer attached I made a small trip (about 10km) on a nice road and that’s when I noticed it … When I reach 90/100/110 kmh the steering wheel started vibrating a lot … Sad
As I was 350 km away from the tyre dealer I went to a near one to have the 4 wheels balanced (only, did not aligned them)… He solved it, said the wheels had too much weight on, and the Defender behaved well , till now …
Now I’ve done some more 1500km since and I’m having the same problem …
In my 90 I changed tyres about 3 times (always BFGoodrich) and never had this problem …
Could it be one of the wolf rims that is defective ? Is it the tyres ? What should I look for ? Should I go and have the wheels balanced again ? And aligned ? Only made 60 km off road (large road, no big obstacles) … Do I have to balance the wheels every 1500 km ? Big Cry
Thanks Regards
Joao
'10 Land Rover Defender 110 CC
'08 BMW F800GS
'64 SIIA Forward Control
'69 SIIA 109 ZA CKD
_____________________________________________
You have the right to remain silent. Anything you say will be misquoted, then used against you.
Post #40232 9th Sep 2010 3:48pm
iruffell
United Kingdom 2009 Defender 110 Puma 2.4 XS CSW Zambezi Silver
Probably just need balancing, the nature of the imbalance will determine what speed you feel the vibrations.
Also check there is no mud etc on the rims as a small amount can nock the balance out very quickly.
Post #40233 9th Sep 2010 3:57pm
MK
Sounds like balance to me. Perhaps you should rotate/move a bit the worse tire against the rim. Perhaps it is on the limit of what a machine can do. MTs are sometimes tricky. Puma 110" SW
Post #40234 9th Sep 2010 4:02pm
bob neville
Balance weight fallen off ?
Have you tried swapping the front and rear wheels round ?
Bob
Post #40235 9th Sep 2010 4:19pm
roel
Netherlands 2003 Defender 90 Td5 PU Caledonian Blue
Try balancing powder.
I have that in my front tyres with BFG MT's 235 -85's Since that was put in I never had any unbalance in my front tyres unless there was a big junk off sticky clay on the inside off my rim. There are no balancing weights on my front tyres.
But first check if the rims are straight and the tyres are mounted even. Roel
1984 90 2.5 na Diesel - RR V8 (1994-2001)
1997 Camel Trophy Discovery 300TDI (2001-2009)
2005 G4 Discovery III 4.4 V8 (2008-2018) It's gone but it still hurts.
2003 90 Td5 (2009-now)
Post #40245 9th Sep 2010 9:41pm
landy andy
got eactly the same with mine. Only started with new wheels, have swapped them around, had them rebalanced, but all this changes the wobble but does not remove.
Now going to check bushes and swivels.
Andy
Post #40250 10th Sep 2010 7:15am
lrmaniac
Andy
I'll try to swap all the wheels, remove tyres, fit them again, balance and align all the wheels ... Let's see ... Sad
It should solve, I hope, because before I fit them, with the standard factory wheels and tyres, the Defender used to run smoothly, no vibrations at all .... Regards
Joao
'08 BMW F800GS
'69 SIIA 109 ZA CKD
Post #40257 10th Sep 2010 9:14am
MK
Try to be present when doing the job and check out the conditions of each rim and tire. Also, just in case, look if you have mud stuck on the internal side of the rims as it can cause serious vibration. Puma 110" SW
Post #40260 10th Sep 2010 9:21am
pouf
Greece 2009 Defender 110 Puma 2.4 SW Zermatt Silver
pedro i have heard about this, a friend of me says it is really work
 www.newfoundland.gr
Post #40261 10th Sep 2010 9:21am
roel
Thats what I said, balancing powder.
Look again at my picture there are no weights on the front tyres, there are weights on the rear tyres.
It really does work. I drove already 50000 km with these tyres and the front still don't need balancing the rear start to wobble. Roel
Post #40307 10th Sep 2010 10:02pm
landy andy
Solved mine today Mr. Green Mr. Green Mr. Green Mr. Green
Changed all the front end bushes, and the track rod ends (Thanks Army Bob).
Then even went for laser alignment Thumbs Up Thumbs Up
(The wobble had gone before)
Drives very very nice now.
Andy
Post #40652 16th Sep 2010 5:28pm
