![]() | Home > My Defender > Corris 110.... |
| mcma1 Member Since: 16 Oct 2012 Location: Northern Ireland Posts: 2947
Well its works just lovely....
Measured up all the bits today on the CMM and designed it up in CAD, printed off the cutting, drilling template.. Click image to enlarge Panel trimmed and drilled.. Click image to enlarge Motor on to panel first time.... I slotted the holes very slightly just to centre the motor and regulator with a centre pin and then tighten all up. Click image to enlarge Test fit doorcard, every clip in place... Click image to enlarge I have ordered a new Bearmach RH motor as i just need to make sure the gear, diameters are consistent incase i need to made some variations but its rock solid! :thumbsup: Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
And the switch surround off the printer which i will soft tool next if anyone wants them...
Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
| BuckBlu110 Member Since: 19 Apr 2014 Location: in the pub Posts: 736
^^ yes please!
| L110CDL Member Since: 31 Oct 2015 Location: Devon Posts: 11094
Spot on Andy
Clayton. |
Good time to get some sound proofing well around the door internal too!!
| Retroanaconda Member Since: 04 Jan 2012 Location: Scotland Posts: 2788
Nice work. Watching with interest.
| Tiger Member Since: 06 Jul 2012 Location: Wales Posts: 2265
Would a D2 rear door handle with window switch fit?
Possible, can't see why not. If I didn't have the second cubby it's probably the route I would investigate Andy
| Morepower Member Since: 08 Jan 2013 Location: Fife, Scotland Posts: 630
Hi Andy... I'm interested in this 'Kit' also please... Maybe a good idea if you could do a 'shopping' list for those of us who are LR challenged...
Cheers Tim It doesn't matter how bad it is, It can always get worse... 2013 Bowler 110 (Sold) 2016 Bowler 90 Rally Spec (Sold) |
no problem,
the new drive shaft should be machined today, i just need to check over an aftermarket motor as some people may pick up either old disco or new Bearmach/Britpart. Andy 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
Anyone with the double din install may or may not have seen this but i found that mine did not sit flush towards the top... and i have noticed it on a few other installs i have since...
it has annoyed me since it was fitted and then today i lost a clip in behind so ended up stripping it all back, found the clip and also the cause, the HU was just pressing against the ducting at the back so a little touch with the heat gun and i just pushed it back a little... dash now fits perfectly. Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
Few more bits arrived today.... Lots to do!!
Click image to enlarge Click image to enlarge Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated 2014 Fuji 110 SW LS3 https://www.defender2.net/forum/post751233.html#751233 2014 Corris 110 SW http://www.defender2.net/forum/topic40056.html My old Xtech 90 build.. http://www.defender2.net/forum/topic15681.html LS3 V8 build... http://www.defender2.net/forum/topic49051.html |
| Oakseywick Member Since: 20 Dec 2014 Location: Cirencester Posts: 1002
I like the grill andy
Thanks, I wasn't entirely sure about it but have to say it's lovely. Have a day off today so really need to get stuck in once I get the kids off to school and the dogs exercised! Andy
| All times are GMT |
