![]() | Home > Maintenance & Modifications > Mounting Plinths - NAS style lamps |
Mike_B Member Since: 23 Jan 2011 Location: Moray Posts: 550 ![]() ![]() ![]() |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6681 ![]() ![]() ![]() |
As long as you are using LED throughout you can use the SVX plinths on the rear, part number LR009773
This is for the rear only, on the front you would have to use an aftermarket stepped plinth. Martin ![]() ![]() |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2539 ![]() ![]() ![]() |
Hi Guys, many thanks for your quick responses.
Mike_B. The Bolt on Bits are exactly what I want. I'm in Bradford on Monday so I will call in and pick a couple up. Martin. I'm only fitting NAS style on the rear. I'm putting Mobile Centre lamps on the front |
Griff_L322 Member Since: 26 Mar 2015 Location: North Wales Posts: 89 ![]() ![]() ![]() |
Bolt on bits easy fit are perfect for a quick fit.
Had them front and rear on our td5 |
