Home > Maintenance & Modifications > Steering Guard: Belly Fender, anyone tried one?
m33ufo
Wales
Came across this whilst looking at steering guard options:
http://www.duckworthparts.co.uk/landrover/info_bfdef0003.html
Looks very nicely finished. Anyone tried one?
I also like the standard LR offering but it's quite pricey - not that the Belly Fender is cheap!
Smile
Post #453588 9th Sep 2015 10:45am
I like that, I think it looks fab !
I note that the red eyelets are for lashing down rather than recovery though
Post #453593 9th Sep 2015 10:59am
K9F
Never heard of it before your post. Does look good on the face of it. Is it lacquered? Even the lacquer on my OEM one degraded and resulted in me having it powder coated.
Steering guards all do exactly the same and there is a bucket load of threads with pictures. As mentioned I have a third-hand OEM one that I powder-coated black I bought off the forum. I do not off-road or green-lane so it is purely for looks and could potentially have been made out of plastic for my purposes. It depends on your intended usage of the truck and whether you want functionality over form? Happy hunting!
Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #453596 9th Sep 2015 11:01am
m33ufo
Wales
I'm looking for a well made good quality unit. This one is CNC machined so it should be accurately manufactured. Also has some nice touches - wider than most guards and I quite like the contrasting red lashing hoops and frame.
It'll be 99% decorative so no point in carting around an excessively heavy unit. This looks perfect for me - but £295 from Duckworths.
Post #453620 9th Sep 2015 1:04pm
leeds
Am not surprised that K9F has not heard of Belly Fender as they are a newly incorporated company.
There are many steering guards in the market place starting around the £100 mark going upwards.
Personally I would be reluctant to have lash down eyes in contrasting colours. That is typically done with recovery points and sooner or later the temptation might be to use the lash down eyes for recovery.
Yes the Belly Fender does look good but if the price does look expensive m33ufo why not buy a cheaper one and get it painted to your own design or powder coated in contrasting colours?
Good quality well made products do tend to cost more to manufacture then cheap roughly made products. The Belly Fender is wider then most other steering guards hence less can be cut out of a sheet of metal also pushing price up.
Brendan
Post #453632 9th Sep 2015 1:52pm
m33ufo
Wales
Good point re the lash down eyes.
Have to say the Belly Fender item is probably the nicest I've seen - with the exception of not having recovery points. Dan at Duckworths has offered £220 + vat (£264), so I'll go for it.
Post #453634 9th Sep 2015 2:02pm
Clemmo
Have to say I like the look of the Belly Fender..
But Im with Brendan...not keen on the idea of the red tie downs??
Would ineveitably be mistaken as a towing/recovery point. Whistle
Maybe would have been best maufactured without?..or at the very least painted Gloss Black?
Clemmo Thumbs Up
Post #453655 9th Sep 2015 3:45pm
I am not convinced that the the red doobries are just tie-downs and not recovery points. They appear to me to be securely attached to the fairly hefty brackets inboard of the frames that hold the plate in place, and look sturdy.
I notice elsewhere on Duckworth's site it states "The mounting brackets are 5mm mild steel with integrated 16mm diameter lashing hoops", but 16mm dia on a 5mm plate is monstrous overkill for a "lashing point".
Anyone have any info from the manufacturer?
Post #453670 9th Sep 2015 4:54pm
m33ufo
Wales
Here you go.
http://www.lro.com/land-rover-products-par...ing-guard/
I quote:
"The lashing hoops aren't designed for heavy recovery, but will accept a pull with a 10° cone in line with the chassis."
Post #453672 9th Sep 2015 5:02pm
A very thorough answer, thank you! Thumbs Up
Post #453725 9th Sep 2015 8:03pm
m33ufo
Wales
No problem....now I just need the vehicle to attach it to. October sometime!
Post #453741 9th Sep 2015 8:33pm
leeds
Must admit I like this part of the description
Quote:
The CNC-machined plate has 2.5mm radius curves on all forward-facing edges
Good attention to detail there which shows quality
Brendan
Post #453767 9th Sep 2015 9:07pm
m33ufo
Wales
Exactly what I thought. Happy paying marginally more for a well considered / well made product.
I was tempted initially by a black Urban Truck guard:
http://www.ebay.co.uk/itm/Urban-Truck-Land...2ca0257918
But then read a post about one rusting quite badly on this forum.
Post #453772 9th Sep 2015 9:19pm
Roy5695
United Kingdom 2011 Defender 110 Puma 2.2 XS DCPU Indus Silver
I like it. Can I squeeze one on the credit card without the wife noticing...
Post #453773 9th Sep 2015 9:22pm
m33ufo
Wales
Dan at Duckworths did mine for £220 + vat. Go for it Smile
Post #453782 9th Sep 2015 9:37pm
