Home > Tdi > 300tdi service
Tia4
United Kingdom 1998 Defender 90 300 Tdi SW Cairns Blue
300tdi service
I'm looking to get my 90 serviced it's only done about 3000 miles since it was last serviced where it had all fluids changed what should I be looking to have done or do myself . It's done about 112000 miles.
Post #453366 8th Sep 2015 2:33pm
g-mack
personally i would be doing engine oil & filter, greasing all nipples and usual visual checks! no need for all other oils, maybe chuck in air filter as they are cheap enough. My 109 thread
my youtube channel
Post #453371 8th Sep 2015 3:29pm
shaggydog
^ +1
Plus drive it more, Defenders don't like sitting Thumbs Up Running Restoration Thread http://www.defender2.net/forum/post323197.html#323197
Post #453373 8th Sep 2015 3:34pm
dave18
United Kingdom 1984 Defender 110 300 Tdi CSW Portofino Red
Grease and lube everything that moves, apart from the bits which shouldn't move in which case fix them, check and top up levels. Thats about it. 3k osnt a service interval. Ive done that in 14 days on holiday.
Know ita full of errors but the Haynes manual has a good service break down or I know the proper LR one is avaliable on the net some where.
Post #453454 8th Sep 2015 8:48pm
Tia4
Thanks for your replies think I might give this a go myself any preference for oil and what Grease should I be using, and grease guns have read that some don't fit the nipples, sorry to ask silly questions but thinking of doing this for the first time.
Post #453664 9th Sep 2015 4:42pm
Mo Murphy
Do your fuel filter too.
50 Shades of Pennine Grey
Post #453692 9th Sep 2015 6:21pm
sgilmour
United Kingdom 1994 Defender 90 300 Tdi CSW Arles Blue
Great thread, I've not done a service on mine yet either and not sure to what standard the last was done.
Thinking about checking/changing all oils/fluids, filters, and want to get the cambelt done because the dealer didn't know when it was last done and I don't want to risk it. Changing rocker cover gasket too.
Also spent 3 days with the front submerged in clay and water recently Big Cry so going to deep clean and WD anything that should move and doesn't, then tighten up anything that does move but shouldn't Rolling with laughter
Post #456567 20th Sep 2015 4:52pm
