![]() | Home > Maintenance & Modifications > Rubbish windscreen washer...WHY??/ |
Check the nozzles are clear [use a pin or thin bit of wire] and then adjust where the spray hits the screen using said pin or bit of wire in the hole of the nozzle which in fact are spherical so are able to rotate slightly in their housings - if no improveent is noted report back and someone will offer you words of advice on what else to look for in what is basically a very simple system while your manservant brings you a nice cup of tea and a biscuit.
Whatever happened to Defender owners with a bit of application ![]() Owned numerous Land Rover vehicles of all shapes and sizes over the decades. Current Defender: A non tarts hand-bagged Puma 110 XS USW. [Insert something impressive here such as extensive list of previous Land Rovers or examples of your prestigeous and expensive items, trinkets, houses, bikes, vehicles etc] http://forums.lr4x4.com I used to be Miserable ...but now I'm ecstatic. |
gilarion Member Since: 05 Dec 2013 Location: Wales Posts: 5139 ![]() ![]() ![]() |
I put it down to some owners never owning a Meccano set or building a crystal radio when young. ![]() Or as a young lad never even taking apart your mum and dads wind up alarm clock or similar to see how it worked ![]() http://www.youtube.com/user/conwy1 |
Price up a Jeep whilst you're there!
![]() ![]() Treat every day as if it is your last....one day you will be right!! |
Screbble Member Since: 26 Apr 2015 Location: Lancashire Posts: 2293 ![]() ![]() ![]() |
Mine's so effective it leaks into the footwell......
Cuthbert Member Since: 26 Oct 2013 Location: Up North Posts: 1535 ![]() |
I think the word 'flaccid' best describes the performance of the washer jet performance on my 2014 model. Although as with any pumped solution, there is a difference and trade off between pressure and volume to be considered. As others have indicated it might be worth adjusting the nozzles with a pin to get the fluid in the optimum position on the windscreen. Alternatively doing a D.I.Y. modification to get a four spray high pressure installation might be an option? |
discomog Member Since: 09 May 2015 Location: Notts/Lincs Border Posts: 2542 ![]() ![]() ![]() |
Sounds to me like RRUK's Puma is suffering from an enlarged prostate. Trust me I'm a doctor. You'll either have to reamer it out (painful) or top it up with cranberry juice.
rossy Member Since: 29 Nov 2010 Location: Co. Roscommon Posts: 1297 ![]() ![]() ![]() |
or a handful of pumpkin seeds in the reservoir
mse Member Since: 06 Apr 2008 Location: UK Posts: 5117 ![]() ![]() ![]() |
Im sorry meccano is rubbish...lego all the way Mike |
