![]() | Home > Technical > Will a 2015 steering wheel fit my 2001 TD5? |
| Go Beyond Member Since: 30 Jan 2012 Location: Headcorn, Kent Posts: 6678
First you need to count the splines on your existing steering column, it'll be 36 or 48.
The 2015 wheel is 48 spline however it won't have the pins that cancel the indicators ( you need a 2014 or earlier) |
| All times are GMT |
