Home > In Car Electronics > Tweeters
Barney12
United Kingdom 2014 Defender 90 Puma 2.2 XS CSW Corris Grey
Tweeters
Hi, I asked this question in amungst another thread but I think it got lost..........
Is the factory fit tweeter on the 90 (June 2014 vehicle) a standard 1" fitment? I.e. can it be swapped without too much grief?
Also is there a FF crossover hiding under the dash or is it just wired direct with the front speakers?
TIA
Post #449394 26th Aug 2015 2:05pm
Martin
Site Admin
The crossover is in the standard tweeters, and they are 1".
Plenty on here if you do a search Wink
http://www.defender2.net/forum/search.php?search_keywords=tweeter  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #449400 26th Aug 2015 2:16pm
Barney12
The scary bit is I DID search and still didn't find the answer Embarassed
Post #449434 26th Aug 2015 4:24pm
Davegouldenpuma
Martin you show the Alpine tweeters that are standing up proud of the dash where can i get them??
Post #453844 10th Sep 2015 8:14am
K9F
Google it.....plenty of options there from £19:99 upwards! Whistle Thumbs Up
Following part numbers may help!
SPS-110TW
SPR-10TW If you go through life with your head in the sand....all people will see is an ar5e!!
Post #453846 10th Sep 2015 8:26am
Barney12
Just a word of caution in that with the Puma the way that the dash is moulded with a slight rise it makes the fitting of Alpine 1" tweeters less than absolutely perfect. Yes they will fit the hole (with a bit of fettling) but the grille edge will overlap the raised contours. You might have the same problem with pods.
I've seen suggestions that the Focal tweeters are a better fit but I've never seen any pictures in the flesh to prove that.
Personally I decided to re-use the existing factory fit tweeter grilles. See my thread here:
http://www.defender2.net/forum/topic39623-15.html
HTH
Post #453854 10th Sep 2015 8:43am
Your wish
Thumbs Up
Post #453871 10th Sep 2015 9:57am
Barney12
Excellent thanks Ken.
That picture also shows the raised area of dash clearly too which I reference in my post.
By the way upgrading the factory fit tweeters has a HUGE impact on sound quality. Thumbs Up
Post #453895 10th Sep 2015 11:16am
Venomator
ken wrote:
Your wish
Thumbs Up
Focals look good and do an admirable job on top and under the dash... Thumbs Up
Mr. Green
 Rog... Mr. Green
The GREEN One...
MY2016 Urban Truck Build Thread - http://www.defender2.net/forum/topic40548....al[/color]
Post #453913 10th Sep 2015 1:15pm
Indeed, but it'd be the last item I'd choose to upgrade of the lot in order of importance.
They can all wildly differ in price too.
Post #454563 12th Sep 2015 11:13pm
MGDM4
Is Focal the only make of speaker that people use?
What would fit in an 04 TD5?
Matt
Post #469564 4th Nov 2015 11:02pm
