![]() | Home > Technical > Range Rover Air COn |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2242 ![]() ![]() ![]() |
Have had similar symptoms with another vehicle if it starts to work okay again at lower temperatures. Turned out to be the air gap was too large on the magnetic compressor clutch. Worked fine with a cold engine and in the winter but warm engine and high air temperatures and it would either not engage at all or would cycle on an off too frequently. Noticable by the click-click-click of it cutting in and out every 5secs or so.
Never bothered to fix it myself but there was a lot of info on various Volvo sites about re-shimming the clutch. Not too sure on how accessible it is on an L322 TDV6 or V8 though. Steve 02' 110 TD5 Double Cab Rebuild Thread |
At least that's easy to check.
RRUK Site Supporter Member Since: 31 Mar 2010 Location: Leicestershire Posts: 2037 ![]() ![]() |
You might want to join our forum and /or read this too for a simple fix...
http://www.fullfatrr.com/forum/topic33288.html?highlight=air+con 2016 D4 HSE 1998 110 TUM HS FFR Hard Top XD WOLF 1982 Series 3 SWB Petrol |
Snowy90 Member Since: 23 Feb 2015 Location: Surrey Posts: 482 ![]() ![]() ![]() |
Thanks I will check it out.
Always nervous of after market quick fixes, but certainly looks like the problem is a very slow leak |
