Home > Maintenance & Modifications > Should I +50mm lift or no??
LoveB
2013 Defender 110 Puma 2.2 SW Orkney Grey
Essentially I just want a bit more flex. I've never actually found myself in a situation where I thought 'gee I wish I had a bit more flex'... even with wheels in the air I dont really think wish that tyre was on the floor lol but I wouldnt mind it.
was thinking koni raids or something. what do you guys suggest? have been told TF is no good but the ones that came with my disco 1 seemed ok. dont want to go more than 50mm/2 inches. I might just be wanting it cause of the 33's I just put on but I suppose the main question is, is it worth doing anyhow?
Post #445734 13th Aug 2015 11:34am
K9F
Do you offroad/greenlane?
I also have large wheel/tryre combo which equates to 33" and have thought the same as you. Ultimately 6 years later having spent the money on other things it is a decision I did not regret not having it done. Are you considering it 'because you 'need or rather want' it? Mine was a desire for the latter. You may also wish to consider castor correction which can inflate the cost further with a 2" lift?
Very much a personal choice I feel. Thumbs Up
 If you go through life with your head in the sand....all people will see is an ar5e!!
Post #445736 13th Aug 2015 11:39am
need4speed
It depends what your trying to achieve.
If it's a lift mainly in order to fit larger wheels/tyres, then a 2" will not only suffice but be a lot cheaper. A 2" lift is within the range of standard trailing/radius arms. A 5" lift is most definitely not.
The main point to remember here (and a point a lot of people forget) is the fact that no amount of suspension lift gains you clearance under the axles. Only larger tyres, or a portal axle conversion does that...
Post #445740 13th Aug 2015 11:53am
LoveB
Yes I do a bit of offroading. but heck, before I put my tires and snorkel on (ive not even found the use for the snorkel yet LOL)
my only mods were a 2nd hand set of side steps.
moreso want than need then. I wouldnt mind more flex - but at the same time I dont get my wheels off the ground every time.
I know I'll need to atleast change springs at one point. i want to add a winch in time which will sag the front. hence why I thought should I get a 50mm lift or should I jsut get HD springs or something.
even when I fit 33x12.5 wheels/tyres it didnt rub unless it was on full flex.
and the funny thing - the only time ive been bogged was when I had 33x12.5 on.. when I drove through the same hole earlier with my standard wheels and did it again and again Rolling with laughter
Maybe I shoudl just go crazy and get portals? I'm not sure how much livers sell for these days though!
but yes, all in all, more need than want. I dont thin kthe 33's will wreck anything. would be good to get more downward travel. so maybe just HD springs and longer travel shocks or?
Post #445741 13th Aug 2015 11:54am
K9F
need4speed wrote:
...... A 2" lift is within the range of standard trailing/radius arms. ...
Interesting how views differ.....here are a couple of responses from my thread on the same subject.......
A resounding "NO!"
big steve wrote:
simon from devon 4x4 would sugest you dont need any sort of castor correction on a 2 inch lift ?
regards steve
Followed by a "YES YOU DO!"
BigMike wrote:
K9, what's the reason for the lift? If you already have HD springs etc what will it achieve? in terms of degrees it wont neccessarily be 3 degrees, it ll depend on how you lift it using what components. Are your HD springs OEM or aftermarket? if the latter, you may find already that you have a lift. It's easy to tell, just measure from the top to the bottom of the spring. Standard (on a unladen 90 anyway) when on the vehicle itself are 300mm. If yours are any longer that's the amount of your lift. Not sure what they are on a 110
and yes, you will need correction arms.
No idea where Simon from Devon 4x4 is coming from with that steve, there is a marked difference in the arms, you can just kneel down and see the change in angle and its effect on the bushes. Plus, 2" on the front and you'll probably need a double cardon prop, depends on if you feel vibration of not but at 2", its likely.
ETA - your radius arms might need doing as well. It's a lot of money really just to lift your truck a bit unless there is a good reason (a good reason to you of course)
I suppose the confliction may have been a contributing factor why I binned the idea. Both comments were made by respected and knowledgable forum members.
Forgot to add about extending brake hoses it all soon adds up to a considerable amount! Thumbs Up If you go through life with your head in the sand....all people will see is an ar5e!!
Post #445742 13th Aug 2015 11:58am
need4speed
People who own/run businesses are always going to push for the sale.
I'm only going by personal experience whereby 2 of my friends both have 2" lifts in order to fit larger tyres. 1 is an OME lift and the other is a Terrafirma light duty lift. None have experienced any trouble regarding accelerated ware in the trailing/radius arm bushes.
1 experienced prop vibration but it turned out that was due to a worn UJ.
Post #445745 13th Aug 2015 12:07pm
K9F
need4speed wrote:
People who own/run businesses are always going to push for the sale. .
Really?
The "NO" came from someone at Devon 4X4 if you read it correctly who was obviously not pushing for any sale whatsoever? Whistle If you go through life with your head in the sand....all people will see is an ar5e!!
Post #445746 13th Aug 2015 12:09pm
need4speed
Lol fair point regarding Simon Laughing
My personal view would be try without. It's no biggie if you find you do need to fir castor corrected arms in the future..
Post #445749 13th Aug 2015 12:12pm
LoveB
might elave it out for now. maybe HD sprigns when I get a winch.. then lose my mind and find portals lol
Post #445750 13th Aug 2015 12:13pm
K9F
Agree...trial and error to get the evolved perfect result. I couldn't be faffed when it was a want, not a need! Potentially it could have cost a damn sight more than I had budgeted for (think about £750 if memory serves at that time.) Also I realised that my 08 XS came at that time with HD springs fitted as standard that gave me a 1" natural lift over non XS spec anyway.
Post #445751 13th Aug 2015 12:14pm
Might get a little extra height but HD's are designed for weight aren't they and probably limit flex.
I need new springs so I guess I'll have to measure the free height of my current springs seeing as I don't know what they are. Confused
They aren't standard though.
Remember top and bottom spring isolators can give you some slight slift without any issues with anything else.
I was thinking of HT softer 2400kg springs with top and bottom isolators.
So softer spring with touch of height from the isolators too. ( and dampened vibrations)
I suppose it depends what I'm running on now though, they don't seem like HD springs to me.
They were yellow though. Shocked
Agree on the point above that it's a common misconception that the axles are lifted by suspension by some.
Indeed, only portal axles or larger tyres do that.
Portals and bigger tyres might end up being easier in the grand scheme of things.
As Mal mentions above the cost does mount up quickly.
Post #445757 13th Aug 2015 12:32pm
LoveB
portal axles nearly 25k to do... Think I'll just drive around the ruts Rolling with laughter
Post #445943 14th Aug 2015 12:27am
landy andy
Talk to Gwyn Lewis.
Plenty of flex, handled better than standard setup, lasted, and didn't fail, no massive lift required.
Post #445964 14th Aug 2015 8:16am
K9F
Landy nice pictures but scant on detail, how much was the final outlay if you don't mind me asking and what was done and with what parts please? If you go through life with your head in the sand....all people will see is an ar5e!!
Post #446029 14th Aug 2015 11:08am
Hufflepuff
Boys boys boys!
This is of massive interest to me - as I'm about to push the button and order a lift kit myself.
I've also fitted 33" tyres on alloy Mach 5s, and they do rub on the arches (although it seems only just).
There is a lot of discussion about whether a 2" lift warrants all the extra bits or not. It seems 2" is about the limit - so you 'can' get away without the extras if you want to.
Fortunately I've been putting the pennies into the piggy bank for a while and can now afford to get all the gubbins including:
Wide angle propshafts
A-frame ball joint
Extended brake lines
Castor correction arms
... But my nagging doubt is if I do this how will the vehicle drive afterwards?
A 90 is no sports car - but it currently handles fine on the road (XS spec to anti-roll bars front and rear). If I lift by 2" am I going to be creating a wallowing leviathon?
Landy Andy you said that the Gwyn Lewis setup handled better than standard - was that with a 2" lift? If so, did yours have anti-roll bars prior to fitting?
Post #446070 14th Aug 2015 1:38pm
